Correct tire sizes
Old Nov 24, 2007 | 03:53 AM
Mark's Avatar
*Bounty Hunter*
Default Correct tire sizes
For the most accurate reading on my speedometer, what would be the best tire size to run on civic si wheels? The car has a good drop on it as well.
Looking to get some azenis on them...
Old Nov 24, 2007 | 07:30 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Correct tire sizes (Mark's 1.8T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mark’s 1.8T &raquo;</TD></TR><TR><TD CLASS="quote">For the most accurate reading on my speedometer, what would be the best tire size to run on civic si wheels? The car has a good drop on it as well.</TD></TR></TABLE>
It depends on what kind of car the tires are going on. Care to tell us the year, model, and version of your car?
You can also use the tire calculators (see links in the FAQ for this forum) to compare the outer diameter of tire sizes to your stock tire size, to find the one that's closest in diameter.
Old Nov 24, 2007 | 02:09 PM
Mark's Avatar
*Bounty Hunter*
Default Re: Correct tire sizes (nsxtasy)
Ahhh sorry its a 94 gsr :x
Old Nov 24, 2007 | 05:15 PM
nsxtasy's Avatar
H-T Order of Merit
Sorry, I forgot to ask you, which year Civic Si are the wheels from? The wheels had different diameters in different years.
The best sizes for your car are the ones shown in the FAQ topic stickied at the top of this forum:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Forum Rules and FAQ - READ BEFORE POSTING &raquo;</TD></TR><TR><TD CLASS="quote">
<FONT SIZE="4">Tires FAQ</FONT>
What size tires should I get?
The proper size depends on your car, not just the wheels you are using. So if you want to ask what size you should get, let us know what kind of car you have!
For a CRX, del sol, or pre-'96 Civic, the following sizes are usually best:
13" - 175/70-13
14" - 185/60-14, 195/55-14
15" - 195/50-15
16" - 205/40-16, 195/45-16
<FONT SIZE="4">For an Integra or '97-00 Civic, the following sizes are usually best:
14" - 185/65-14, 195/60-14
15" - 195/55-15, 205/50-15
16" - 205/45-16, 215/45-16
17" - 205/40/17
</FONT></TD></TR></TABLE>
Here is how much the diameter differs from stock for these sizes, so they throw off your speedometer by the same percentage:
195/55-15 (stock size)
185/65-14 (+0.1 percent)
195/60-14* (-1.0 percent)
205/50-15* (-1.6 percent)
205/45-16 (-0.8 percent)
215/45-16* (+0.7 percent)
205/40/17* (+0.1 percent)
*The Falken Azenis RT-615 is available in sizes marked with an asterisk.
christ0pher
Nov 7, 2007 07:37 AM
Solo2Vtec
Honda Civic (2006 - 2015)
12
Nov 21, 2006 12:59 PM
jbell
Apr 23, 2004 05:42 PM
darkvibe
Jun 15, 2003 01:17 PM
