Clutch will not disengage
Old Nov 24, 2007 | 01:55 AM
portenio78's Avatar
Default Clutch will not disengage
I finished up my GSR swap in the Del Sol and at the same time I replaced many things. As for the tranny I went ahead and had the flywheel resurfaced and installed a new complete Competition Clutch kit. Drove the car for about 10 miles and it drove great. The only thing I did not like was the clutch disengaging right off the floor board. Now I cant disengage it at all. I tried adjusting the pedal....nothing. Bought new slave and master cylinder...same. I have bled multiple times. I think I can see what the problem is, and that is that the slave is only moving the release fork 1/4 inch. The release fork sits in the middle like its supposed to as well. If I could get another inch out of it I would be golden. Is removing tranny my only option left?
Old Nov 24, 2007 | 06:55 AM
portenio78's Avatar
Default Re: Clutch will not disengage (portenio78)
up for more info
Old Nov 24, 2007 | 07:10 AM
Under_Pressure's Avatar
Was the master and slave replaced with oem parts?? did u find any leaks??
Old Nov 24, 2007 | 08:53 AM
portenio78's Avatar
Default Re: Clutch will not disengage (Under_Pressure)
no leaks, all oem, and great pedal pressure
Old Nov 24, 2007 | 09:20 AM
did u lube the shaft??? maybe the clutch doesent slide out... could also be the forks bent somehow or the pivit point is worn out....
Old Nov 24, 2007 | 10:26 AM
Chiovnidca's Avatar
Broken clutch pedal bracket maybe?
Old Nov 24, 2007 | 10:41 AM
portenio78's Avatar
Default Re: Clutch will not disengage (Chiovnidca)
fork is good and pedal is perfect. Could the flywheel have been stepped wrong? Could the brand new pressure plate be faulty?
Old Nov 24, 2007 | 10:54 AM
i say let the car run for a while the clutch may not be slidding off the shaft because u did not lube it properly or something. Most of the time the vibrations from the motors will losing it up some.
Old Nov 24, 2007 | 01:01 PM
Hanmin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">Broken clutch pedal bracket maybe?</TD></TR></TABLE> check that
Old Nov 24, 2007 | 01:48 PM
portenio78's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Under_Pressure &raquo;</TD></TR><TR><TD CLASS="quote">i say let the car run for a while the clutch may not be slidding off the shaft because u did not lube it properly or something. Most of the time the vibrations from the motors will losing it up some.</TD></TR></TABLE>
Tried, no go.
portenio78's Avatar
Default Re: Clutch will not disengage (Hanmin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hanmin &raquo;</TD></TR><TR><TD CLASS="quote"> check that</TD></TR></TABLE>
Its perfect.
Old Nov 24, 2007 | 02:15 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by portenio78 &raquo;</TD></TR><TR><TD CLASS="quote">Could the flywheel have been stepped wrong? </TD></TR></TABLE>
Did you check it? It's supposed to be .065" if I remember right.
Old Nov 24, 2007 | 02:42 PM
Legion's Avatar
* B A N N E D *
This is going to sound crazy, but...
I was having the same problems. I replaced the master/slave cylinders, bled the lines over and over again, adjusted the pedal, dropped the trans two different times to replaced the pilot/throw-out bearings and re-torque the clutch plate...
I did everything. Nothing worked. Until... I drained the trans fluid and re-filled with syncromesh. The problem went away instantly.
Don't ask me why/how it worked. I also ended up using much less than the service manual called for. I remember filling the trans up to the capacity listed in the helms, but then I opened the over-flow bolt and about half the fluid poured back out (on level ground). That was also a bit of a mystery, but I've been running like that for 6 months now and it shifts like butter.
Old Nov 24, 2007 | 05:14 PM
portenio78's Avatar
Default Re: Clutch will not disengage (Legion)
Its got Synchromesh in it right now. I can visually see the release fork only moving 1/4 inch. Can someone please take a pic of the slave and fork with their clutch pedal pressed all the way in.
Old Nov 29, 2007 | 05:58 AM
portenio78's Avatar
up
Old Dec 4, 2007 | 09:33 AM
portenio78's Avatar
Old Dec 4, 2007 | 09:44 AM
5150CIVIC's Avatar
did u try adjusting the pedal, open the vlave in the master so u actually get play to build pressure, i ran into this problem once. check that see whats up.
Old Dec 4, 2007 | 11:10 AM
4g hatch's Avatar
Default Re: (5150CIVIC)
on the fork spring was the tabs on both sides wore or broke
Old Dec 4, 2007 | 12:04 PM
portenio78's Avatar
Default Re: (4g hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g hatch &raquo;</TD></TR><TR><TD CLASS="quote">on the fork spring was the tabs on both sides wore or broke</TD></TR></TABLE>
ball, spring, tabs, and fork were fine.
Old Dec 8, 2007 | 08:46 AM
CTR01's Avatar
Is it the Right Slave for the car? what was wrong with the old one?
Old Jan 6, 2008 | 04:04 AM
portenio78's Avatar
Default Re: (CTR01)
Well I dropped the tranny and I found nothing. PP and disc look fine, as does the flywheel. Also the throw out bearing and release fork seem to be in good condition. I'm starting to think i just got a bad brand new pressure plate??? I might throw in a good used stock clutch kit I have to find out.
yunebug
Jun 15, 2010 07:29 AM
zrs6v4
Jul 30, 2009 10:22 PM
ddtfrom626
May 6, 2009 10:02 AM
portenio78
Nov 27, 2007 03:33 PM
egizzle8
Aug 2, 2004 02:52 PM
