Boost gauge light
Old Nov 23, 2007 | 07:19 PM
Mr_ET's Avatar
Default Boost gauge light
Hi all,
I just received my Garrett boost gauge and it has 3 wires. One is power, one is the ground and the third one is for it to light up at night.
I want to know what I should wire this one to. The radio in my civic si does not have a wire for the dimmer from wiring diagrams I have seen so that won't work.
What wire would be the easiest to get to, and whats the color/location?
thx!
Old Nov 23, 2007 | 07:30 PM
crxfreak1117's Avatar
Default Re: Boost gauge light (Mr_ET)
i hooked mine up to my guage light dimmer switch so whenever u turn ur lights on it will turn the guage on hope this helps
Old Nov 23, 2007 | 07:37 PM
Mr_ET's Avatar
Default Re: Boost gauge light (crxfreak1117)
is there only 1 wire going to the dimmer?
If I remember properly you can just pop the dimmer button out and expose the wire(s) right?
Old Nov 23, 2007 | 08:52 PM
lalo's Avatar
thats correct
Old Nov 24, 2007 | 02:35 AM
Mr_ET's Avatar
Default Re: Boost gauge light (lalo)
from what I read on here their are 3 wires for the dimmer a black ground a red dimmer wire and a red/black that is the constant 12v and that's the one that should be tapped as the red will invert the dimming effect in the gauge versus the cluster lights right?
Old Nov 24, 2007 | 05:24 AM
correct
mcgee*
Mar 7, 2007 02:18 PM
draxxus07
Aug 21, 2005 03:52 PM
4DRmafia
Mar 25, 2005 12:42 PM
GDM Z28
Feb 27, 2004 07:00 PM
sneakypete
Jan 15, 2003 05:42 AM
