CRX 91' starting issues
Old Nov 23, 2007 | 02:46 PM
CicaTriZ's Avatar
Default CRX 91' starting issues
I have a 91' CRX SI.
Having a problem getting it to Run.
~Changed the plugs, with the right gap.
~Changed the Distributor Cap and Rotor.
~Changed the Plug wires with new.
~Installed a New Battery.
The problem comes down to it that the original owner had a car alarm installed in it. They tried to remove the alarm to figure out why the car randomly died and wont start up.
I checked the Fuel pump "Blk/Y" wire to see if they put the Kill there, the wire was untouched.
Correct me if im wrong but when i put the key in, and turn it to the acc position, shouldn't i hear the Fuel pump prime up??
The car will turn the starter, but it just wont fire up.
Question on the ECU, i noticed it has some LED's on it, Do those Light up at all?
Any trouble shooting guides to follow by would be greatly appreciated.
Old Nov 24, 2007 | 05:32 AM
crxfreak1117's Avatar
Default Re: CRX 91' starting issues (CicaTriZ)
do u hear a clicking from a relay under the drivers side dash whenever u turn the key on if not check ur main relay that will caust the fuel pump not to turn on just something i would check first
Old Nov 24, 2007 | 06:42 AM
CicaTriZ's Avatar
Default Re: CRX 91' starting issues (crxfreak1117)
Yeah i hear the click from the main relay. The motor turns just wont fire up. I dont hear the fuel pump prime.
Old Nov 24, 2007 | 07:36 AM
~sp33~'s Avatar
EFB055
The motor will still turnover if your main relay is farked. Its probable that your fuel pump has had it though.
Old Nov 24, 2007 | 07:45 AM
Default Re: (~sp33~)
yeah i was aware that it would still turn over but wouldnt allow the fuel pump to turn on so i agree with the guy above check the pump
Old Nov 24, 2007 | 02:10 PM
CicaTriZ's Avatar
Default Re: (crxfreak1117)
I guess theres a Relay in the glove box, that works for the fuel pump. Im gonna trace through that area to the pump.
Cause the car alarm that was installed by tweeter was a clifford alarm, of coarse that company no longer exists so i can't get a wire layout from them to figure out what they did to kill it.
hehe i wont surrender, ill keep hacking at it til i get the beast started.
Old Nov 24, 2007 | 05:17 PM
CicaTriZ's Avatar
Default Re: (CicaTriZ)
Nope no relay behind the glove box. I tested the main relay and it works fine from what i read in the book. Its gotta be the pump.
Old Nov 24, 2007 | 07:41 PM
CicaTriZ's Avatar
http://www.autozone.com/az/cds...s.htm
This is what i've been looking at by, damn i feel like banging my head into the wall. LoL No wonder the car is having issues i look at the fuel pump and it shows 4 wires, where the diagram shows only 2. humm...
So the relay i tested works, i tested to the honda books specs, but i get no power to the relay. And as i can see the wires are hooked up right.
The pump dosn't turn or makes any sounds, hence the relay.
brezzent
Audio / Security / Video
Oct 25, 2011 06:28 PM
ef8sleepr
May 4, 2011 01:54 PM
egthomas
17
May 20, 2009 02:21 PM
fracas
26
Dec 11, 2005 08:59 AM
