Who Here has swapped Dizzy Distributor Internals?
ok, who here has swapped Dizzy internals or taken one apart?
How do you take out the most bottom Sensor? I cant seem to find a combination of differnt moves and angles to get that thing out of there. Ive taken apart and reasembled it like 3 times, but i have never been able to take that one out(meaning i tried 3 times).
Is there some sort of trick to get that top plate off. I know there are 3 screws holding it underneath, but how do you get to them?
There has to be something im missing here. Im worried that when i dissamble my good dizzy for the internals, im gonna bang up the sensors and theyre not gonna work.
H22/3 OBD I Dizzy. Swapping internalls with a F22 Dizzy
ya, but how do you get a screwdriver to the other side. There is a like no room whatsoever. No even a little stubby screwdriver will fit in there
never mind, i got it the shaft off. Did know you could.
http://www.cb7tuner.com/vbb/showthread.php?t=88245 is where i got it from. I hope this helps someone
