D15..D16
Old Nov 23, 2007 | 03:11 AM
djspecter's Avatar
Default D15..D16
ok I just picked up a 93 civic non vtec for 300 bucks running with no title but im fixing tht as you read this. And in the trunk i found a D16 head with Vtec. And well my main question is can i install it on my car or it wont work?
Old Nov 23, 2007 | 08:11 AM
Ketone's Avatar
Default Re: D15..D16 (djspecter)
SEARCH in the FAQ at the top of this forum, and you will find a post created on doing this swap (aka mini-me swap)
Old Nov 23, 2007 | 08:18 AM
Cln94EG1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djspecter &raquo;</TD></TR><TR><TD CLASS="quote">ok I just picked up a 93 civic non vtec for 300 bucks running with no title but im fixing tht as you read this. And in the trunk i found a D16 head with Vtec. And well my main question is can i install it on my car or it wont work?</TD></TR></TABLE>
Rock that **** Mini-Me lol they can be fun
Old Nov 23, 2007 | 08:29 AM
olatz's Avatar
Old Nov 23, 2007 | 12:00 PM
jordanhxc's Avatar
definately will work...do it up
Old Nov 23, 2007 | 02:43 PM
djspecter's Avatar
Ok will do then. I never used to like honda's...well the honda community around here. ANd after driving one man it is freaking awesome!!!!! I am a proud owner of a honda.
Old Nov 23, 2007 | 04:23 PM
Dasfinc's Avatar
Default Re: (djspecter)
Please be aware, if your car is a CX, the Vtec head may not work, Please check my Write-up as I dunno if 93's have 4 valve pistons if its a CX
Old Nov 23, 2007 | 06:35 PM
djspecter's Avatar
um..how do i know what model do i own? Cause i cant find it on the rear of the car. lol
Old Nov 23, 2007 | 06:45 PM
charlieboyhonda's Avatar
dont worry I have a mini me swap and works perfectly and is a CX, in the CX model the head ir 8 valves but the pistons are 16 valves
Old Nov 23, 2007 | 06:46 PM
hmtcrxsir's Avatar
i think you will also need to get oil jets from a vtec engine if you were to use the z6 head
Old Nov 23, 2007 | 06:49 PM
man just go to the FAQ and search for the mini me swap and use does instructions man I used them in my swap and work perfectly and mine is a d15 block with a d16y8 head and work very very well and mine was 8 valves (CX)
Old Nov 23, 2007 | 07:04 PM
Syndacate's Avatar
Default Re: (hmtcrxsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmtcrxsir &raquo;</TD></TR><TR><TD CLASS="quote">i think you will also need to get oil jets from a vtec engine if you were to use the z6 head</TD></TR></TABLE>
Talk = End.
The oil jets are there on all Z6, Z1, and B7 blocks, you just have to pull the plug out on B7 blocks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dasfinc &raquo;</TD></TR><TR><TD CLASS="quote">Please be aware, if your car is a CX, the Vtec head may not work, Please check my Write-up as I dunno if 93's have 4 valve pistons if its a CX</TD></TR></TABLE>
I'm pretty damn sure you're right, but not positive.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djspecter &raquo;</TD></TR><TR><TD CLASS="quote">um..how do i know what model do i own? Cause i cant find it on the rear of the car. lol</TD></TR></TABLE>
There's an engine stamp to the left of the exhaust header (when looking at the engine from the front), on the vertical axis of where the engine meets the transmission. It's a rectangular extrude from the engine block.
D15B8 is the CX's 8 valve motor.
D15B7 is the DX/LX's 16 valve motor (more up to par for a mini-me swap)
I don't know if it'll work on a B8 block, but if you have a B7 block, it'll work fine for sure.
Here's the write-up for the '92-'95 mini-me how-to.
Old Nov 24, 2007 | 01:37 PM
Dasfinc's Avatar
Default Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
Ima have to disagree with the 'more up to par' part, The B7 and B8 Blocks are identical, The B8 at one point just switched to 8 valve pistons (The bore and stroke are the same)
MAIN diffrence would be the tranny as the CX tranny is even wider gearing than the DX/LX.
Old Nov 24, 2007 | 07:23 PM
djspecter's Avatar
Ok so to make things simple I have a D15b7. Its that a ok head swap to do?
Dre_miller
Aug 4, 2016 08:43 AM
1234567899876543211230
Nov 4, 2006 11:02 PM
CSims
May 1, 2005 09:16 PM
Honda-Hooligan
Oct 11, 2004 06:45 PM
accord87
Jul 19, 2004 09:33 AM
