Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Car Shaking
Old Nov 22, 2007 | 02:29 PM
Dustin99's Avatar
Default Car Shaking
So i take my car in yesterday to get a flat tire fixed...not a big deal. So today i head out to work and as soon as increase the speed past 70ish(km) the car has alittle shake then once it hits 100 it shakes pretty good. I just got the alignment done a few months ago and also replaced the struts...could it potentially be the tire just needs to be re-balanced or should i put looking for something else?
Old Nov 22, 2007 | 02:35 PM
Harlowe's Avatar
Function>Fashion
Have you checked your lugnuts?
Old Nov 22, 2007 | 02:43 PM
Dustin99's Avatar
Default Re: (Harlowe)
have done all of them are tight
Old Nov 22, 2007 | 02:44 PM
Harlowe's Avatar
Function>Fashion
Hmm. Maybe they didn't balance your tires or something? Dunnoz
Old Nov 22, 2007 | 02:45 PM
Dustin99's Avatar
hmmm i hope thats all it is! car hopefully will be checked tomorrow
Old Nov 22, 2007 | 02:51 PM
Shintakun's Avatar
hrmmm even if the lugs are tight i have had discount tire be stupid and put the wheel slightly angled. take them off and put them back on your self.
Old Nov 22, 2007 | 02:57 PM
Dustin99's Avatar
Default Re: (Shintakun)
that would make sense i'll try that out tonight and see how it goes
Old Nov 22, 2007 | 05:11 PM
sixonethree's Avatar
Default Re: Car Shaking (Dustin99)
balance em
Old Nov 22, 2007 | 05:50 PM
IncaEM2's Avatar
yes, most likely they did not rebalance
Old Nov 22, 2007 | 06:02 PM
Dustin99's Avatar
Default Re: (IncaEM2)
i took the tire off put it back on seem to help but im going to go get them to check the balancing just to make sure, thanks for all the help guys!!
Old Nov 22, 2007 | 07:49 PM
DsevenEm2's Avatar
im pretty sure they balanced them.. but theres ways to not do it properly or good...lol. so they probably just did a crappy balancing job.. or sometimes the tire has to take a "getting used to" but that usually results in a pull.. are u getting a pull at all?? shaking usually=balance problem..
Old Nov 23, 2007 | 06:28 PM
PasswordEM2's Avatar
well if the car wasnt shaking before the flat repair.... best bet is that they did not rebalance them. (assuming it wasnt shaking before)
Old Nov 24, 2007 | 08:18 AM
Dustin99's Avatar
Default Re: (PasswordEM2)
no the car wasn't shaking before, got them to blanace them again and everything seems to be fine thanks for all the help!!
Sorcin
Aug 13, 2010 09:18 AM
Deezz_Nuttz
Honda Civic (2006 - 2015)
17
May 7, 2007 08:10 AM
imroadk1ll
21
Feb 28, 2007 05:00 PM
envious1320
Mar 29, 2004 05:38 PM
