how to change wheel studs
Old Nov 22, 2007 | 11:55 AM
Al-sonic's Avatar
Default how to change wheel studs
i have a 92 civic and my wheel studs broke and i am dont know how to fix it can anyone help me. like tell step by step how to change the wheel studs
Old Nov 22, 2007 | 12:07 PM
92civic104's Avatar
Default Re: how to change wheel studs (Al-sonic)
its pretty easy to do just alot of work i can email or pm you how to do it if you would like
Old Nov 22, 2007 | 12:20 PM
JKov240's Avatar
Default Re: how to change wheel studs (92civic104)
I think all you have to do is take the wheel off, then remove the brake assembly, then take a hammer to it and beat it out...pop the new one in and put everything back on.
Old Nov 22, 2007 | 12:27 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: how to change wheel studs (JKov240)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JKov240 &raquo;</TD></TR><TR><TD CLASS="quote">I think all you have to do is take the wheel off, then remove the brake assembly, then take a hammer to it and beat it out...pop the new one in and put everything back on.</TD></TR></TABLE>
Not enough room to do it this way. You have to press out the splined hub from the bearing to get them out and in.
Old Nov 22, 2007 | 12:38 PM
instrument's Avatar
there's a walk through in the faq
you should always check the faq before posting.
good day sir.
Old Nov 22, 2007 | 01:53 PM
Pure Sol's Avatar
Default Re: (instrument)
you could grind off some of the stud where it catches the hub, make a little more that a D shape and beat it in. Not the correct way to do it but I used it on a Sunday, out of town, with little to no tools and drove it home. Worked for me for a year and a half now.
Old Nov 22, 2007 | 02:14 PM
JKov240's Avatar
Default Re: how to change wheel studs (mcvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec &raquo;</TD></TR><TR><TD CLASS="quote">Not enough room to do it this way. You have to press out the splined hub from the bearing to get them out and in.
I remember changing one out on a '00 Civic sedan that way...might be different for the earlier models.
Old Nov 22, 2007 | 02:25 PM
Syndacate's Avatar
<FONT SIZE="5">Here's a very detailed writeup with lots of pictures on how-to do it.
&gt; "OMG, Syndacate, where did you find that?"
&gt;&gt; "Well, my friend, it was on the big 'FAQ' thread stickied at the top of this forum."
&gt; "You mean I didn't even need to search and just wasted everybody's time by creating a new topic?"
&gt;&gt; "Yes, and to think, these write-ups were already assembled in the FAQ and stickied for your (and the rest of H-T's) ease."
idiot</FONT>
Old Nov 22, 2007 | 02:27 PM
JKov240's Avatar
Default Re: how to change wheel studs (Syndacate)
^Calm down bro...it's Thanksgiving Day. You should be thankful for people that don't search.
Old Nov 22, 2007 | 02:42 PM
civic.slow's Avatar
* B A N N E D *
dont hammer it in from the back.......grab a stack of washers and impact the lugnut on and pull it in and torugh with the gun (tightening) it pops in
Old Nov 28, 2007 | 12:35 PM
Kyjerry414's Avatar
Default Re: how to change wheel studs (civic.slow)
Cant you hammer it in from the back with a rubber mallet slowly so you dont damage the thread? I have a broken stud as well.
I have ARP extended wheel studs and could i just replace all 8 OEM studs by cutting and hammering it in from the back? Has anyone replaced all 8 studs with extended wheel studs doing this method?
kvastek
Honda Civic (2001 - 2005)
Jan 11, 2022 05:29 AM
RBeckner
13
Jul 31, 2006 04:14 PM
turbob16ef
Suspension & Brakes
Sep 3, 2005 12:16 PM
SeattleBoy
Suspension & Brakes
Apr 26, 2005 07:02 AM
