skunk 2 mani question.....
ok well I have a skunk 2 pro series manifold for a d16z6
The problem i'm having is that the temperature sensor that I have from stock doesn't fit into the hole that skunk 2 provides for you.
Now I know for sure that skunk 2 doesn't sell a temperature sensor for this, so what should I do? how can I make it fit in there?
if ur car is 96-00 u need to keep the IAT sensor in the air intake tube or get a 92-95 IAT and extend your wires across.
if ur car is 96-00 and u are using ur IAT, you need to plug that hole. you can tap threads in the hold and put a screw in there, or make a block off plate, or make a thing with a nipple on it and have another spot for a vacuum source.
I mean yeah but then what's gonna hold it up? like the stock bolts that hold it up on the stock manifold, also don't fit in there. so even if I stuff it in what's gonna hold it up for it not to fall out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FrancoGT1 »</TD></TR><TR><TD CLASS="quote">uyt</TD></TR></TABLE>
what is that?
what is that?
Beau Gotti
Oct 7, 2008 05:43 PM
Eyal 951
Sep 7, 2006 12:04 AM
Emoson
Aug 10, 2004 05:35 PM
