need help with p24 ecu pins
I have a 96 civic with a vtec and did a motor swap and everthing hooked up fine but i found that the motor has two oxygen sensors one at the top of the exhaust and one at the bottom. But the cars harness only has one connector to hook to and when car is started the check engine light comes on with a code p0141 for the o2 sensor. the guy that owned the car before me said that there is a way that i could wire up the second o2 sensor to the ecu in the car he said it is a p24 ecu. im not sure. so the question is, is it possible and does anyone know what pins and how to go about it . but if it isnt possable what should i do about the check engine light.
Modified by Doo1224 at 6:29 AM 11/23/2007
ef8-dc2619
Jan 31, 2007 04:29 PM
EGbeater
Dec 17, 2003 07:02 PM
