Which axle?
Old Nov 22, 2007 | 10:13 AM
freshvibes's Avatar
Default Which axle?
I just bought a car and the passenger side axle is clicking every time I turn. The old 4spd motor was swapped out last year with a 5spd d15b out of a 94 civic. So which axle would I need to use?
Old Nov 22, 2007 | 11:17 AM
ludesrv's Avatar
Your stock ones will work fine.
Old Nov 22, 2007 | 05:00 PM
de_sjiem's Avatar
Default Re: Which axle? (freshvibes)
not sure, but i know the stock ones for the 4sp tranny wont fit... (they have a different size axle. We had a civic with the 4sp, and replaced the axle, and only the 4sp axles fit on it.. we got the wrong axles cuz we had the wrong engine code)
Old Nov 22, 2007 | 05:43 PM
Tippyman's Avatar
Default Re: Which axle? (de_sjiem)
OK.
The inner spline of the axle (the part that goes in the tranny) is the same in all EF's.
The outer spline changes with the type of hub you have. The 4 speed tranny comes in an Std. You need axles for an Std.
Old Nov 22, 2007 | 05:46 PM
Guiding my way back.'s Avatar
* B A N N E D *
Default Re: Which axle? (Tippyman)
couldnt he just find a si or dx outter cv hub and put it on his axle....
Old Nov 22, 2007 | 05:49 PM
Tippyman's Avatar
Default Re: Which axle? (Guiding my way back.)
If you wanna do a hub swap be my guest. I'd just rather get the right axle.
Old Nov 22, 2007 | 08:44 PM
freshvibes's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">OK.
The outer spline changes with the type of hub you have. The 4 speed tranny comes in an Std. You need axles for an Std.</TD></TR></TABLE>
Ok, but is the inner spline the same from the 94 civic as an ef?
Old Nov 23, 2007 | 07:54 AM
ludesrv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by freshvibes &raquo;</TD></TR><TR><TD CLASS="quote">
Ok, but is the inner spline the same from the 94 civic as an ef?</TD></TR></TABLE>
Yup. But I think the length is different and won't work.
guedo148
Aug 27, 2008 02:23 PM
The Dirty EJ1
Sep 3, 2007 04:34 PM
Audi RS4
Sep 10, 2003 02:04 PM
redstorm82
Dec 18, 2001 07:33 AM
