gsr with tapped b16 head
Old Nov 22, 2007 | 09:10 AM
hspoon's Avatar
Default gsr with tapped b16 head
got a gsr, but i just bent a valve so my homeboy gots a b16 but it used to be in his ls vtec. and its tapped where u supposed to do it with ls vtec..
so my question can i used the head???? am i gonna have to run the line thru the outside for the head?
any help would be appreciated...
thanx in Advance
Old Nov 22, 2007 | 09:20 AM
killerpenguin21's Avatar
Default Re: gsr with tapped b16 head (hspoon)
you could just untap it...
Old Nov 22, 2007 | 09:27 AM
hspoon's Avatar
Default Re: gsr with tapped b16 head (killerpenguin21)
well i was gonna do that but its seal.. he just told me that...
another question wat head bolt do i use..??? gsr???
Old Nov 22, 2007 | 09:52 AM
what do you mean sealed? usually you only plug it with a set screw...
look here
https://honda-tech.com/zerothread?id=1676914
Old Nov 22, 2007 | 10:24 AM
hspoon's Avatar
i know is weird... but there's no plug, is just been sealed with something
Old Nov 22, 2007 | 10:46 AM
DonF's Avatar
Do you own a drill?
Old Nov 22, 2007 | 12:47 PM
gsrious's Avatar
in all honesty... just run the head with the tapped line aswell. the extra oil in the head will thank you.
Old Nov 22, 2007 | 01:07 PM
DonF's Avatar
Default Re: (gsrious)
Why is that, a -4 line is actually smaller in ID, than the block hole diameter and much longer. Please explain. Being dumb, I do not understand why a smaller, longer line, can increase oil flow.
BlakeJ53
Dec 28, 2006 01:34 PM
hondaj05
Aug 1, 2006 05:42 AM
kaj
Jul 5, 2005 11:34 PM
KiNG $h!t
Jul 8, 2004 09:06 PM
90INTGS
Dec 2, 2002 08:44 PM
