half shaft wont come out!!! HELP!!!
Old Nov 22, 2007 | 12:15 AM
Rhymenoceros's Avatar
Default half shaft wont come out!!! HELP!!!
Im trying to pull my tranny out..and my half shaft bolts in the block are seriously in there.. i tried.. me.. and a air rachet.. i was wondering if you could pull the tranny out without take out the half shaft.. by when i remove the bolts.. try to slide it to the side.. then out.. has anyone attempted this or done this???
Old Nov 22, 2007 | 01:01 AM
flatblack-h22's Avatar
Default Re: half shaft wont come out!!! HELP!!! (Rhymenoceros)
half shaft as in intermediate shaft? its 3 14mm and i wouldn't think it should be that hard, unless whoever did it before you welded it
Old Nov 22, 2007 | 01:54 AM
civic.slow's Avatar
* B A N N E D *
Default Re: half shaft wont come out!!! HELP!!! (Mr.EGG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.EGG &raquo;</TD></TR><TR><TD CLASS="quote">half shaft as in intermediate shaft? its 3 14mm and i wouldn't think it should be that hard, unless whoever did it before you welded it</TD></TR></TABLE>
its hard to meld low carbon to aluminum, even with tungsten where dissimilar metals are preferred for that type of welding, given the position and uselessness of running a bead there im willing to bet it does not have a bead on it of any sort
try using an impact wrench, with those air ratchets they dont have enough intial TQ
i hate that too where its on the bolt/nut and you hit the trigger and it sends your fingers into a crevice or side of the block....gives you a good pinch huh! LOL
Old Nov 22, 2007 | 02:26 AM
adamrg85's Avatar
get some pb blaster, wd 40 or any thing that you like to use and get a hammer bang on all three bolt hard but not to hard than get a strong socket or breaker bar, take a pipe about 2 to 3 ft long and put it on the end off your tool and the should come right out. done it 3 times and it worked every time for me
Old Nov 22, 2007 | 12:16 PM
Default Re: (adamrg85)
nice im going to try that thank you!
Chenzo
Sep 30, 2014 04:13 PM
Greatness
Jan 15, 2010 05:21 PM
Wayne_Curr
Feb 12, 2006 05:41 PM
CTL
Mar 8, 2004 07:11 AM
