(Check Engine Light) -Please help-HURRY
Old Nov 21, 2007 | 07:23 PM
ej2 coupe's Avatar
Default (Check Engine Light) -Please help-HURRY
I won a 91 si with jdm b16. When i bought it it also had a wir tuck. But my big concern is the check engine light doesnt come on. I took the cluster out, and seen that the bulb for check engine was blown. So i went ahead and replaced it. put it back in and it didnt come on when i turned the key over.....now im confussed....borrowed a friends cluster and put it in and still did no come on....
SO NOW MY QUESTION IS
How do i go about or what do i check to see what going on and get it to work .....Thanks in advance
Old Nov 21, 2007 | 10:10 PM
ej2 coupe's Avatar
common someone has to let me know where to start?
Old Nov 22, 2007 | 04:14 AM
Chiovnidca's Avatar
Default Re: (ej2 coupe)
Have you checked the wire from the light to the ecu?
Old Nov 22, 2007 | 04:45 AM
ludesrv's Avatar
Are you still obd0? If so the ECU will flash any codes. If not, well that might be bad. If you aren't throwing any codes and the cars running fine I wouldn't worry about it. Id take my time figuring out what the problem is then fix it accordingly.
Easiest thing to do is to figure out which wire is for the CEL then I'd just replace it with a fresh wire. Eliminates any wiring harness problems that way which can take hours upon hours to fix if you try to find the break and solder it.
Old Nov 22, 2007 | 05:26 AM
Chiovnidca's Avatar
Default Re: (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">
Easiest thing to do is to figure out which wire is for the CEL then I'd just replace it with a fresh wire. </TD></TR></TABLE>
I think it would be easier to check it with an ohm meter. Might even be able to see a problem with it near the ecu since someones been jacking with the wiring.
Old Nov 22, 2007 | 08:51 AM
ludesrv's Avatar
Default Re: (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
I think it would be easier to check it with an ohm meter. Might even be able to see a problem with it near the ecu since someones been jacking with the wiring. </TD></TR></TABLE>
Set it to detect continuity. Then go from the CEL pin out at the ecu to the CEL pin in at the cluster. If you have continuity you know the wire is good in itself. Then I would check that wire to ground, if it has continuity. If it does with ground I'd replace the wire.
Old Nov 22, 2007 | 05:41 PM
crxsi89's Avatar
is the ecu chipped or stock?
Old Nov 22, 2007 | 05:43 PM
Guiding my way back.'s Avatar
* B A N N E D *
Default Re: (crxsi89)
does the car run if not its a bad engine ground my car did the same thing.
CRXB18C1_ALL MOTOR
Feb 12, 2022 09:15 PM
OMGBBQTEHWTFDOOD
Oct 19, 2007 10:18 AM
SleeperGSR
Jul 15, 2007 10:05 AM
jdm82
Mar 7, 2006 01:08 PM
sushtsi
Jun 10, 2002 11:16 PM
