Suspension & Brakes Theory, alignment, spring rates....
coilover?
Old Nov 21, 2007 | 07:15 PM
mxjoe388's Avatar
Default coilover?
ok so my brother got me a set of these adjustable coilovers springs.i have 100% stock suspenion and was woundering if i could use them instead of the springs that r on there.there is def a huge difference in the size of the springs
Old Nov 21, 2007 | 08:34 PM
rawkus's Avatar
Default Re: coilover? (mxjoe388)
If the springs came with adjustable sleeves, something that looks like this...
Then you MIGHT be able to use them. If they are just springs, then no, you can't use them. Either way, I wouldn't recommend using them with a 100% stock suspension.
Dan
Old Nov 21, 2007 | 09:30 PM
mxjoe388's Avatar
Default Re: coilover? (rawkus)
yea thats what i have would it work tho?and what else would u recomend i get.
Old Nov 21, 2007 | 09:43 PM
rawkus's Avatar
Most important is that the coilover was designed to work on your specific car. Some more information on who makes it, even the numbers off the spring (if it has any) or pictures would be helpful. I would always recommend upgrading the dampers (shocks) if installing stiffer springs. Examples of quality aftermarket, performance dampers are Koni Yellows and KYB AGX. I personally own both (one set on one car, one on another) and they exceed my expectations, especially the AGX, considering the price. Sometimes (if not all the time) you need a special sleeve to allow the coilovers to work on the Koni Yellows though.
Lastly, keep the drop modest, roughly 1.5 inches. Lowering more can cause excessive tire wear, wear on suspension components, and a very rough ride if it is extremely low.
Dan
Old Nov 22, 2007 | 07:21 AM
mxjoe388's Avatar
no name or numbers on the springs or sleeves.the sleeves r silver and the springs r red
Old Nov 23, 2007 | 10:24 AM
rawkus's Avatar
Without knowing more about the coilovers, I would shy away from installing them on your car. Look into getting Ground-Control coilovers or another reputable brand.
Dan
Old Nov 23, 2007 | 02:28 PM
mxjoe388's Avatar
what would that cost me?
12345678910jdm
15
Jul 29, 2011 12:53 PM
5STAR3
Suspension & Brakes
16
Feb 24, 2005 03:28 AM
HatchBox
14
Jul 16, 2002 11:59 AM
donutdude
Jun 27, 2002 01:57 PM
