B20 CRX wont star after first start up. help plz
Old Nov 21, 2007 | 06:22 PM
B16A CRX's Avatar
Default B20 CRX wont star after first start up. help plz
After i finished hooking evrything up and finished the swap i cranked the motor and it started after shooting a ball of flame through the intake. probably from the octane booster it had on an empty tank. After filling the tank the motor started again but sounded like it was running on 3 cylinders. i pull out a spark plug wire to put the correct firing order and the car shut off. after properly setting the firing order the motor will not start and there is no spark. changed the distributor and now i have spark but very poor. BTW its a obd2 gsr distibutor with a obd p75 on obd0 injectors. i need help asap. thanks in advance. the car wont start now. grounds are in place.
Old Nov 21, 2007 | 10:56 PM
MoreBoost!'s Avatar
Default Re: B20 CRX wont star after first start up. help plz (B16A CRX)
i hope u didnt try to pull the wires while the engine was running, sounds like u blown your ignition coil and ignitor or even worst your ecu. i would change coil first n see what happens
Old Nov 22, 2007 | 08:08 AM
B16A CRX's Avatar
Default Re: B20 CRX wont star after first start up. help plz (MoreBoost!)
i changed the distributor and got my spark back. the spark plugs are drowned in gas. My father told me to disconnect the main relay and crank the motor for a couple seconds so that all the gas can be burned or something like that. sometimes the motor is about to start but it just dies and keeps turning over but no start.
Old Nov 22, 2007 | 09:18 AM
godruler's Avatar
check your ground on your thermostat housing, when ever you have a spark problem on a honda always check that first.
Old Nov 22, 2007 | 11:09 AM
B16A CRX's Avatar
how do i check if my ignition coil is burned
Old Nov 22, 2007 | 11:18 AM
ludesrv's Avatar
Are you running obd0 injectors on an obd1 ecu?
Old Nov 22, 2007 | 08:14 PM
B16A CRX's Avatar
yup. it cranked up and the car was running until i pulled that distributor plug. i dont know y the injectors would be a problem
Old Nov 22, 2007 | 09:17 PM
Hondacivic91dx's Avatar
sounds like a timing issue to me.if it is popping and shooting flameballs from the intake..
Old Nov 22, 2007 | 09:49 PM
dandizel's Avatar
Default Re: (Hondacivic91dx)
Are you running the resistor box with those injectors?
Old Nov 23, 2007 | 09:25 AM
B16A CRX's Avatar
yes im still using the resistor box. And there is no more flame ***** it was just before it started the first time. i know the firing order is correct 100 %. the motor turns and its right about to start but it dies. it kills my battery after a while of trying to start it. I tried push starting it but it wont start either.
JAYDmManny1331
Nov 22, 2009 09:33 PM
purplexs650d
Oct 17, 2006 12:31 PM
itsm3paul
May 10, 2004 12:49 PM
SOUTHCREX
Jun 18, 2002 08:16 PM
