help, accord is smoking like crazy
Old Nov 21, 2007 | 05:24 PM
1baddturbosi's Avatar
Default help, accord is smoking like crazy
92 accord, just changed the oil 1 hour ago, i took the valve cover off & BRAKE CLEANED
the valves & the camshaft, then poured 5w-30 over them & let it all drain out.
Did i mess-up my exhaust valves or something??
Old Nov 22, 2007 | 07:39 AM
Default Re: help, accord is smoking like crazy (1baddturbosi)
bump, anyone have any advice???
Old Nov 22, 2007 | 08:07 AM
sony224422's Avatar
what color is the smoke?
also did you replace the gasket
Old Nov 22, 2007 | 08:09 AM
Default Re: help, accord is smoking like crazy (sony224422)
gasket is new. the smoke isnt blue, or black. white would prob sum it up.
someone told me to just run it & see what happens, u think i mess up the valves??
Old Nov 22, 2007 | 12:54 PM
Chiovnidca's Avatar
hows the oil level? Is it overfilled?
Old Nov 22, 2007 | 01:23 PM
Default Re: help, accord is smoking like crazy (Chiovnidca)
nope, oil is right on. we believe my valve seals are ****
Old Nov 22, 2007 | 04:29 PM
sony224422's Avatar
i'd venture to say the carb cleaner is just burning off. Drive it a bit and see what happens.
Also, remember, on cold starts you will get white smoke for a while as the water (condesation) burns
Old Nov 22, 2007 | 04:52 PM
after i did it last nite it smoked hardcore & today not as bad. how long will it take to burn off???
Old Nov 22, 2007 | 05:15 PM
sony224422's Avatar
probably a bit of high spirted driving. Take it out on the road and up to redline, of course obey your laws and such. Carb cleaner usually burns white i believe.
Old Nov 22, 2007 | 05:39 PM
i hope your right man. i have done that about 3 times. when i removed the valve cover today, there wasnt any oil in the valve cover by the valves. i put a little bit of oil on the valves again.
just dunno what to do? either it burns off, or i replace the seals
Old Nov 22, 2007 | 06:26 PM
sony224422's Avatar
you may wanna try seaform lol. i don't see how carb cleaner could have done anything.. it might have eaten some seals though.
when you scrapped the gasket off none of it fell in right? also, check the adjustment.
Old Nov 22, 2007 | 06:32 PM
nope. everything was fine. just hope nothing happened to the seals. the valve cover is getting kinda noisy.
Old Nov 22, 2007 | 06:42 PM
sony224422's Avatar
i'd check the adjustment if you think its noisy. i could be wrong but im not sure if theres supposed to be oil in there after the cars off..
Old Nov 22, 2007 | 06:45 PM
yeah there should be oil in there. hope i didnt burn up the valves. just dunno what to do.
Old Nov 22, 2007 | 07:11 PM
sony224422's Avatar
yeah, well i guess all thats left is to check the gap. or inspect the gaskets. im surprised no one else has chimed in
Old Nov 23, 2007 | 05:55 AM
the gap & the gasket for the valve cover are good
Notmyusername
Nov 15, 2018 05:11 PM
osiris22
May 16, 2011 05:31 PM
CarolinaHonda
Feb 4, 2010 05:43 AM
Petekazel
Jul 14, 2004 09:50 PM
snoop_bealybob
Oct 5, 2002 10:16 AM
