EK3 OBD2/DLC connector location?
Hi everyone,
I'm going crazy because no matter how much I look, I can't seem to find the DLC/OBD2 16pin plug on my EK.
I looked under the driver's side dash but came out empty handed. Can anyone give a a clear description (color, relative location to other components such as the fuse box, etc) or maybe post a picture? I'd really appreciate it.
The only thing I found that was vaguely similar to an OBD2 connector was this:
It is behind the left kick panel and bolted to the car so I couldn't get it out. Could it be?
Should be straight above the hood release handle pointing straight down. It will be the normal D shaped OBD2 port.
The piece you have pictured is the grounding junction block.
Things are starting to look ugly.
Just like this guy with a 98 EDM CRV, I can only find the 2 and 3 pin blue connectors next to the ECU.
I saw this 3 pin to 16 pin adaptor on eBay... I wonder if that will give me full OBD2 functionality?
http://cgi.ebay.com/HONDA-3-PI...wItem
Modified by KoRn_vIRuZ at 2:18 AM 11/23/2007
thanks dude...
i will try to look it tomorrow since now it already dark in Malaysia
==> try look it just now. but it fail. not there...
now what shall i do... where is the exact location of the connector....
Modified by civic_ek3 at 3:00 PM 3/7/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_ek3 »</TD></TR><TR><TD CLASS="quote">hello there,
i got a same problem with you.
what is your solution?
I came to the sad conclusion that EDM EKs weren't equipped with OBD2 connectors. Or at least my 97 isn't.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">
by the way where is the 3 pin connector?</TD></TR></TABLE>
It's on the right side of the car, close to the ECU.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KoRn_vIRuZ »</TD></TR><TR><TD CLASS="quote">
It's on the right side of the car, close to the ECU. </TD></TR></TABLE>
I'm pretty sure there is no DLC on the EDM models.
https://honda-tech.com/zerothread/2229150
Honda Civic 97 has 3 pin DLC connector and 2 pin SCS connector, for OBDII advantage we need 3 pin to OBD-II adaptor cable.
If anyone can find out the availablity in pakistan, then please do let me know. or if anyone found another solution to OBDII for honda then do me a favor too, pls.
pliskin679
Feb 14, 2010 11:49 PM
