help, wath is going on with this engine???
Old Nov 21, 2007 | 03:30 PM
jcvelez360's Avatar
Default help, wath is going on with this engine???
ok i got a b18c1 with p7300 pistons, p72 rods and crank ligthen and balanced micropolish, about the head is a b16a2 with skunk2 springs, retainers and valves, ist ported and polish, skunk2 intake with 66mm t body port match,s2s2cams, and cam gears, hondata heat insulating gasket, aem short ram intake, dc sports 4-1 jdm header 60mm piping. it haves a stock pr3 ecu.ç
it was at 164 whp today we tunne it and it mades only 185whp and that was with a cold air intake, the dyno is a dynojet, but the numbers are kind of low.
ok otrher fact is that i live in bogota colombia de altitud is 2600mt about 8500ft the tunner said that the dyno have some device that corrects the atmosferics facts and that the numbers are with the car at the sea level.
opinions, recomendations
Old Nov 21, 2007 | 03:46 PM
I smell secretions's Avatar
From: Looking for Vagina in your Mamma,, skeet skeet
Default Re: help, wath is going on with this engine??? (jcvelez360)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jcvelez360 &raquo;</TD></TR><TR><TD CLASS="quote">ok i got a b18c1 with p7300 pistons, p72 rods and crank ligthen and balanced micropolish, about the head is a b16a2 with skunk2 springs, retainers and valves, ist ported and polish, skunk2 intake with 66mm t body port match,s2s2cams, and cam gears, hondata heat insulating gasket, aem short ram intake, dc sports 4-1 jdm header 60mm piping. it haves a stock pr3 ecu.ç
opinions, recomendations </TD></TR></TABLE>
extra 15whp or so right their
Old Nov 21, 2007 | 03:50 PM
DonF's Avatar
Default Re: help, wath is going on with this engine??? (I smell secretions)
Good numbers with a stock PR3 ECU.
Old Nov 21, 2007 | 05:25 PM
night's Avatar
Default Re: help, wath is going on with this engine??? (DonF)
is the jdm dc 4-1 that bad or what?
Old Nov 21, 2007 | 06:05 PM
jcvelez360's Avatar
im sorry forget about te stock pr3, today we tune it with a haltech
Old Nov 21, 2007 | 06:08 PM
jcvelez360's Avatar
im so disapointed a setup like this, makes arround 200
Old Nov 21, 2007 | 07:36 PM
Combustion Contraption's Avatar
200 dynojet HP is good considering what you listed.
Old Nov 22, 2007 | 07:49 AM
jcvelez360's Avatar
it only makes 185, i was especting something arround 200
Old Nov 22, 2007 | 08:07 AM
DonF's Avatar
Default Re: (jcvelez360)
Not with a stock ECU. 185 is good, hope you did not hurt anything by no tuning and dynoing. A leak test is in order.
Old Nov 22, 2007 | 08:14 AM
jcvelez360's Avatar
its tuned with a haltech
Old Nov 22, 2007 | 08:59 AM
4g hatch's Avatar
yeah but he's saying how long did u run it without tunning it, you may have damaged it like washing out the rings or detonating. how long did u run it like that. either way those are good #'s. a better exhaust and header will pick u up some more power. did he adjust the cam gears. humidity and altitude will affect a dyno from what i read along with tire size front end allignment and tire pressure. engine dyno's you can keep in a controled enviorment.
Old Nov 22, 2007 | 09:13 AM
jcvelez360's Avatar
for a few km only.
so for you teh problem is the exhaust and header, about the cam gears he only use the exhaust one and 1/2 degree
JCushing's Avatar
Default Re: (4g hatch)
why does everyone automatically expect to just get 200 hp like its so easy... wtf oh yeah this is HT and everyone in the all motor forum makes at least 200hp..
you have a mediocre header and small exhaust piping, put something better on and youll prolly get to were you want.
the question is does the car really seem slow to you though? if it was just as fast as it is now and someone handed you a sheet of paper that said 200 on it would you even make this post? is the motor healthy? not burning any oil, no blowby, good compression?
if its healthy and its fast dont worry about the number.
Old Nov 22, 2007 | 10:55 AM
DonF's Avatar
Default Re: (JCushing)
Its simple, he spent a few dollars and got a 21 whp increase, being a loyal H-T reader he expected 40. Stg2 cams and a mild P&P are always worth 40, right?
Old Nov 22, 2007 | 02:33 PM
alterdcreations's Avatar
Default Re: (DonF)
with the right intake and exhaust system along with the right tuner that can work the cam gears
Old Nov 22, 2007 | 02:37 PM
acydphryck's Avatar
so you went from 164 to 185 whp after tuning with the haltech then?? did i read this right??
if it's a stock sleeved B18C motor, that's about right then. however, like everyone said, your piping needs to be bigger and you need a better header for that setup
one more thing, you need to get an aftermarket fuel pump (walbro 195 or 255 lph) and a fuel pressure regulator, if you don't have one yet you need these with those big cams you have in your motor.
Old Nov 22, 2007 | 05:25 PM
jcvelez360's Avatar
i got a fuel presure regulator the injec are at 85% at the maximun power, the compresion is 11.6/1
Old Nov 22, 2007 | 05:35 PM
jcvelez360's Avatar
Default Re: (alterdcreations)
so wath you ment is that some one belive that a engine like this can make 200whp is stupid???
Old Nov 22, 2007 | 05:36 PM
jcvelez360's Avatar
the question is for donF
cmasonrun
39
Jan 2, 2008 09:17 AM
jcvelez360
10
Nov 19, 2007 06:18 PM
jcvelez360
13
Nov 16, 2007 05:55 AM
SkoundrelUSA
23
Jan 30, 2007 03:57 PM
SkoundrelUSA
29
Oct 9, 2006 08:03 AM
