1989 honda prelude starts but quits when engine warms up
Old Nov 21, 2007 | 02:05 PM
justinhood's Avatar
Default 1989 honda prelude starts but quits when engine warms up
so my 89 prelude starts up but once its started for a bit and the engine warms up it dies out and has to sit for a while until you can start it again. i saw a local mechanic and he said it could be the ignition module i got an ignition module to put it but i cant find where its located?
Old Nov 21, 2007 | 02:11 PM
Hawkze_2.3's Avatar
Default Re: 1989 honda prelude starts but quits when engine warms up (justinhood)
Sounds like you're talking about the ignitor in the distributor.
Old Nov 21, 2007 | 04:21 PM
justinhood's Avatar
Default Re: 1989 honda prelude starts but quits when engine warms up (Hawkze_2.3)
will i need a new part or how can i solve this problem? thanks
Old Nov 21, 2007 | 04:24 PM
justinhood's Avatar
do you mean the ignition coil
Old Nov 21, 2007 | 04:26 PM
Hawkze_2.3's Avatar
Well, you said you already got the ignitor right? I would just go ahead and install it and see if that helps.
Take off the distributor cap and you should have access to it as far as I know...
Another place that would probably be able to help you more since you have an older Prelude is preludepower.com.
Old Nov 21, 2007 | 04:28 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by justinhood &raquo;</TD></TR><TR><TD CLASS="quote">do you mean the ignition coil</TD></TR></TABLE>
No the ingnition coil is different from the ignitor. The coil is much larger and has a ignition cable going directly from it to the distributor, while the ignitor is a small little black box...looks more like a computer part than a car part
Old Nov 22, 2007 | 05:42 AM
justinhood's Avatar
i tried to get the ignition module on but there is no way it will go in the distributor cap because it bolts onto something and shouldnt my car not run if the module is done?
Modified by justinhood at 12:46 PM 11/22/2007
Old Nov 22, 2007 | 03:30 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by justinhood &raquo;</TD></TR><TR><TD CLASS="quote">i tried to get the ignition module on but there is no way it will go in the distributor cap because it bolts onto something and shouldnt my car not run if the module is done? </TD></TR></TABLE>
Can you just post a picture of the part you got before you go any further?
Electrical problems like this are generally go on/off randomly becuase of the nature of electrical connections. Your car may run one day and not the next...then run again the next day.
Old Nov 23, 2007 | 09:44 AM
1funryd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">
Electrical problems like this are generally go on/off randomly becuase of the nature of electrical connections. Your car may run one day and not the next...then run again the next day.</TD></TR></TABLE>
It sounds like your Main Relay. Which is located behind your tray left of the steering wheel.
This is a common Honda problem. The car will start and run, and then after you shut if off, it wont start again until you wait a while.
Sean
Old Nov 23, 2007 | 01:21 PM
justinhood's Avatar
Default Re: 1989 honda prelude starts but quits when engine warms up (1funryd)
ok well ill get a main relay tommorow i just got the ignitior /coils and that didnt make a difference.. I dont shut off the car i just leave it running for a bit and it dies itself everytime after about 10 minutes and soemtimes will start back up but than wont stay on for as long of a time, should i try a new main relay?
Old Nov 23, 2007 | 01:28 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by justinhood &raquo;</TD></TR><TR><TD CLASS="quote"> should i try a new main relay?</TD></TR></TABLE>
Yeah, it could definately be the main relay...they're not very expensive anyway. Also might be the ignition switch if the relay doesn't fix it.
DseriezDemon
Nov 30, 2011 12:52 PM
hanford_rex2
Dec 30, 2006 10:46 AM
ChameoPrelude
Aug 12, 2005 01:54 PM
