02 wire up
i have a d15b swap now my o2 sensor wires are not hooked up to a clip the yellow purple gey and brown , now my o2 sensor are 2 black green and a white i need to hook these up any way possible thx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96accordsir »</TD></TR><TR><TD CLASS="quote">yeah but what ones do i connect the the harnes it self </TD></TR></TABLE>
you doing a OBD 1 conversion? the other 4 colors you mentioned are the same that rywire uses in their jumper harness's. if that's what you have then heres what you need..
*Brown-Black
*Yellow-Black (you can't mix these up so don't worry)
*Gray-white
*Purple-Green
hope this helps
*Brown-Black
*Gray-white
*Purple-Green
hope this helps
HXMan
Apr 26, 2002 08:13 AM
