Puting dsm 460cc injecters in my turbo integra integra
Old Nov 21, 2007 | 12:05 PM
Mostecstreethb's Avatar
Default Puting dsm 460cc injecters in my turbo integra integra
Hi I have a set of 460cc DSM injecters lying around and I have stock injecters in my (8 itegra right now and figure my car couldrunn a hella alot better if i switch them the only thing is How do I wire them in I know I have to switch the injecter plugs and wiire in a resister box but how do I wire it in does anyone have any instruckions. Also Does my car need to be tuned to run these because when I put RC370cc inject in my allmotor HB it didnt run right I had to lower it to 20psi what will i have to do to run these. I Have
98 integra ls
gt45 turbo
completly stock motor & ECU except stg2 turbo cams
vortec 12:1 FMU should i chang the ratio
NOS fuel pump
B&M camand flow FPR
Msd ignition with boost retard
Ram air turbo inlet
madrel bent turbo pipeing
Thats it and also with the fuel mods I have and cams how much boost can i run on a 100oct fuel at the track. Thaks so much for the help
Old Nov 21, 2007 | 01:56 PM
Schister66's Avatar
Man U FTW
For starters, you should revise your turbo...i dont think its a "GT45." Secondly, invest in something other than the FMU. Look at getting a chipped P28 and tune it...FMU's are notoriously pieces of ****. They may have worked 15 years ago, but that was then...
Injector resistor wiring....
Old Nov 21, 2007 | 02:51 PM
JDMeg95's Avatar
Default Re: (Schister66)
not to mention dsm injectors are 450cc not 460
Old Nov 23, 2007 | 07:17 PM
JaredKaragen's Avatar
Default Re: (JDMeg95)
thats what I was gonna say... or ask if he drilled em out to be 460... lolz
Old Nov 24, 2007 | 05:49 AM
xenocron's Avatar
Default Re: (JaredKaragen)
Get them cleaned and flow checked as well!
Old Nov 24, 2007 | 05:59 AM
agrn93ls's Avatar
Default Re: Puting dsm 460cc injecters in my turbo integra integra (Mostecstreethb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mostecstreethb &raquo;</TD></TR><TR><TD CLASS="quote">Hi I have a set of 460cc DSM injecters lying around and I have stock injecters in my (8 itegra right now and figure my car couldrunn a hella alot better if i switch them the only thing is How do I wire them in I know I have to switch the injecter plugs and wiire in a resister box but how do I wire it in does anyone have any instruckions. Also Does my car need to be tuned to run these because when I put RC370cc inject in my allmotor HB it didnt run right I had to lower it to 20psi what will i have to do to run these. I Have
98 integra ls
gt45 turbo
NOS fuel pump
B&M camand flow FPR
Ram air turbo inlet
Thats it and also with the fuel mods I have and cams how much boost can i run on a 100oct fuel at the track. Thaks so much for the help</TD></TR></TABLE>
93da9kid
Jan 30, 2011 07:08 AM
308gt4
Jun 4, 2009 02:41 PM
ls integra mike
May 19, 2008 05:37 PM
93civciv
Nov 4, 2005 07:43 PM
masterasia
May 6, 2004 11:46 PM
