b16a swap
Old Nov 21, 2007 | 10:43 AM
Mayhem521's Avatar
Default b16a swap
I just bought a b16a to put in my 98 civic. It's OBDI. Are the only things I need shift linkage and motor mounts? It's a JDM engine, but would the shift linkage and motor mounts out of a 99-00 SI work?
Old Nov 21, 2007 | 11:02 AM
BlueIntegraBoy's Avatar
Default Re: b16a swap (Mayhem521)
Yes, that would be ideal. You'll need the Si rear transmission bracket and driver side block mount.
Old Nov 21, 2007 | 11:12 AM
raphael's Avatar
yes the motor mounts out of an si will work just get the rear tranny bracket.
also youll need some wiring to be done or..
get a 96-00 b-series alternator
96-00 b-series dizzy
96-00 b-series starter
0bd2 > obd1 jumper harness for the ecu
and use the fuel injectors that came with the car
just to let you know im pretty positive you wont pass inspecition in most states. GL thought
Old Nov 21, 2007 | 11:14 AM
Syndacate's Avatar
Default Re: b16a swap (raphael)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raphael &raquo;</TD></TR><TR><TD CLASS="quote">yes the motor mounts out of an si will work just get the rear tranny bracket.
0bd2 &gt; obd1 jumper harness for the ecu
just to let you know im pretty positive you wont pass inspecition in most states. GL thought </TD></TR></TABLE>
Will those injectors be enough?
I thought the non-EX 6th gens (Y7) ran 190's, no?
Old Nov 21, 2007 | 11:48 AM
raphael's Avatar
Default Re: b16a swap (Syndacate)
well assuming he has an ex(d16y8) engine. if he doesnt than he will need to use y8 injectors or any b-series injectors since they are 240cc as opposed to y7 injectors which are 190cc
Toda Party
Jul 15, 2012 09:08 PM
rick_rabies
18
Jun 1, 2009 10:53 AM
92shade
Nov 14, 2008 06:36 PM
invisible
Jan 9, 2007 11:05 AM
