Acetone in gas increase mpg
Old Nov 20, 2007 | 10:52 PM
polyhonda's Avatar
Default Acetone in gas increase mpg
has anybody done this I done some research, and people say it does work, will it mess up my motor in anyway though.
Old Nov 21, 2007 | 01:49 PM
Perfectionist's Avatar
Default Re: Acetone in gas increase mpg (polyhonda)
It's not worth it. The cost negates the benefit. Besides, it will destroy plastic parts in the fuel system.
Old Nov 21, 2007 | 04:17 PM
Sr420Det's Avatar
Toluene works better but does cost around 10 a gallon. It boost your octane around 2 points on 93 octane and you shouldnt mix more than 30%. I dont think it would hurt anything in your fuel system as long as you dont use to much and mix it before you put it in.
Old Nov 21, 2007 | 07:57 PM
IntegraTionR's Avatar
can you say "Cancer"???
Old Nov 21, 2007 | 11:43 PM
polyhonda's Avatar
Default Re: (IntegraTionR)
i see, but yeah I just heard about it, but if it ruins your plastic components then how come some stores sell it in plastic containers
Old Nov 22, 2007 | 06:07 AM
Flashmn's Avatar
Default Re: (polyhonda)
Special plastics, rubber dies fast with acetone. They make plastics that withstand gasoline, whilst when you take a kitchen tupperware, chances are it will melt.
Also its an urban legend. They claim it has something to do with surface tension, but think about it, when you inject it directly with pressure into the manifold, does surface tension play any role. Even if it may sound legit, I put this acetone right there with the turbonator, magnets on fuel lines and other idiotic ideas.
Also I think some people say, you only put a teaspoon of it.. do you have any idea how little the amount of one teaspoon in 12gallons is? Very little and bears no effect.
Old Nov 22, 2007 | 11:56 AM
tofast2belast's Avatar
the ammount of acetone that goes in gas tank is about < or = 3 ounces per 10 gallons. i have read up and done some research on it that at this mixture it wont destroy the rubber peices at a fast rate, rather shorten the life of it by only a little...
another thing i have gathered is that the acetone breaks the surface tension of the gas, thus making it easier to ignite... if this is the case, on turbo and high compression motors i wouldn't suggest it, because of detonation.
xsxnosxsx
Honda Civic (2006 - 2015)
14
Apr 10, 2011 05:01 AM
2k.civic.si
Sep 30, 2010 01:30 AM
allhonda
Sep 25, 2006 04:17 PM
hybridturtle
Mar 22, 2005 04:43 PM
baonest1
Oct 10, 2002 05:47 PM
