blah... is it possible to upgrade from cx calipers to ex calipers???
Old Jun 24, 2002 | 09:48 PM
six.lug.steph's Avatar
Default blah... is it possible to upgrade from cx calipers to ex calipers???
just wondering, if you could swap out the calipers only? just wondering.
Old Jun 24, 2002 | 09:51 PM
tonyxcom's Avatar
Default Re: blah... is it possible to upgrade from cx calipers to ex calipers??? (Alcoholic)
no
Old Jun 24, 2002 | 09:59 PM
Default Re: blah... is it possible to upgrade from cx calipers to ex calipers??? (tonyxcom)
haha. thanks.
Old Jun 24, 2002 | 10:12 PM
JDMvtecDRAGSTA's Avatar
yeah but you gotta change the whole suspension
Old Jun 24, 2002 | 10:30 PM
eh2's Avatar
eh2
are the si and ex front brake system the same?
Old Jun 24, 2002 | 11:01 PM
Katman's Avatar
Default Re: blah... is it possible to upgrade from cx calipers to ex calipers??? (eh2)
no they're not the same. The EX front brake system is actually the whole knuckle/hub/caliper/and rotor (10.4) assembly is that of a 94+ Integra's. They're bigger than the Si front brake's system.
Old Jun 24, 2002 | 11:06 PM
aeolus's Avatar
Default Re: blah... is it possible to upgrade from cx calipers to ex calipers??? (Katman)
which si are we talkin about????If its a 92 and up si,yess the brakes are the same.the 10,4" rotor,caliper and knuckle
[Modified by aeolus, 8:08 AM 6/25/2002]
Old Jun 24, 2002 | 11:26 PM
heiyu's Avatar
Default Re: blah... is it possible to upgrade from cx calipers to ex calipers??? (aeolus)
auctually the ex and si are not the same (dont know about the abs si though) i got some AEM brakes for my 93 si and they only fit ex's so i had to swap out the brakes for a ex one. Also im pretty sure the si rotors are bigger than the ex. I can check i still have them both
Old Jun 24, 2002 | 11:44 PM
C1V1C's Avatar
not on the 92-95 HB Si, trust me I have one, it has 4 wheel disc with 9.5" fronts. But I think if it has ABS then it has the 10.4" fronts, not positive though.
Old Jun 25, 2002 | 03:37 PM
Katman's Avatar
92-95 range is what I'm talkin bout..
Old Jun 25, 2002 | 06:48 PM
chillly's Avatar
no they're not the same. The EX front brake system is actually the whole knuckle/hub/caliper/and rotor (10.4) assembly is that of a 94+ Integra's. They're bigger than the Si front brake's system.[/QUOTE]
So the brakes on my 95 EX coupe are the same as an Integra? How about the rear brakes? I did a drum to disc conv. from a 92 Civic sedan w/ABS to my 95EX, of course sans ABS. Could I have used Integra hardware instead? What's the difference if any in the rear rotor sizes between the Civic vs. Integra? Civic rear rotors are tiny (I've seen more substantial looking brakes on mountain bikes) I realize most of the braking force comes from the front brakes anyway, or to be more specific it comes from the friction between the tire and the road, but now I'm just curious as to what's the level of commonality between the civic and 'Teg.
dasaboi
Dec 21, 2010 09:01 PM
hondaon18's
Apr 21, 2010 06:58 AM
pd0019
Honda Civic (2006 - 2015)
11
Jan 26, 2007 03:24 AM
DC_RaceR
Apr 22, 2006 11:59 PM
spooncivic1
Mar 22, 2006 11:36 PM
