I'm off to the dealer in the morning, small headaches!
Whats the best question I should ask them, I want them to check the whole car out. And woul like to be able to get these thing covered under the warrenty if possible, Also would they or could they run a ecu/dianogstic check on it?
The reason I'm going is my ignition does not allways work on the first shot,
My driver side window gets stuck halfway up and is VERY slow too,
A loud clunking noise from the driver side rear suspension,
My exhaust is really rattleing bad,
The driver seat is clicking and I noticed a small extra worn spot (maybe my fat ***)
Thanks for any help, H-T has the best know-it-alls !
mine does this too, please let me know how it turns out
You can pull the door panel and check the rubber guides for the window. They can come unglued from their mounts and muck things up good. Happened to me, although my window was only slow going down. It was a bitch and a half to get that right, and if it happens again I'm paying someone else to fix it.
For the ignition, you can check the starter with a multi-meter. Put the negative wire on the negative battery terminal and the positive end on the wire connection to the starter (you have to carefully pull back the rubber boot, but don't pull the wire out of the connector) and have someone turn the key. If you're getting power to the starter motor, but the car isn't starting you need a new starter. If you get no power to the starter it is likely the safety switch on the clutch.
Oops, these are things you can check yourself. As far as the dealer questions go, I would just describe the problems and let them figure it all out.
[Modified by MK Ultra, 2:01 AM 6/25/2002]
Just got back from the dealer and this is what they said...
We'll order the new heatshields for the exhaust and the seat frame for you under warrenty, as for the window they sprayed some cleaner then lube and it works( no chit I do that everyother week) and the clunking under the drivers side suspension the tech could not find anything wrong ot out of place.
And they thought I might get mad, He was nervous about telling me that they have zero parts in stock for my car, Naaa really? so in a week they should have the stuff and will call me...
They had my car for 2.5 hours and it was a fine time at the dealer, no complaints. Alltho they had a PY ITR poster in the customers waiting area that they would not give me...
blueR:
I usually go to flow since its in town, but haven't been there for anything major yet...
my question was for the other Rob aka 01PYITR
Basically
May 26, 2005 10:34 PM
brycerocket
Mar 10, 2003 04:02 AM
