Spark angle Map
Old Nov 20, 2007 | 05:59 PM
svacca1's Avatar
Default Spark angle Map
How would I go about getting a "spark angle map"?
Something that shows what the computer sets the spark angle to under varying engine speeds. I need it for a mid 90's Integra.
How does the spark angle situation change when adding a turbo?
Thanks
Old Nov 20, 2007 | 08:07 PM
NJIN BUILDR's Avatar
Default Re: Spark angle Map (svacca1)
It's more commonly called advance map or ignition advance map.The are many on this site. http://forum.pgmfi.org/index.p...effc7
Old Nov 20, 2007 | 11:16 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: Spark angle Map (NJIN BUILDR)
yeah ignition advance is what most refer to it as around here.
if you get your ecu chipped, any of the software used to do so will have an ignition map that determines the ignition timing.
i seem to remember something like 1 degree retard for every lb of boost.. but i would read up on PGMFI.org before listening to me.
champwhiteEG6
Engine Management and Tuning
Jul 10, 2009 07:52 AM
W O T
Aug 13, 2006 03:27 PM
nickromeo
Feb 10, 2004 08:33 PM
boosted_zc
May 25, 2003 08:58 AM
