another fog light question
Old Nov 20, 2007 | 05:24 PM
tuby's Avatar
Default another fog light question
first, some info on my car....its a 96 civic ex 2dr with 99-00 front end. i just bought these from ebay and was stuck with the harness. please help, i don't know where to plug the single brown plug.....i've searched online and it states to plug it with the single plug that is blue-tapped behind the fuse box but i can't find it on my car. see the picture, its a SINGLE female brown plug that comes out of the switch harness. in the pic, its the plug between the "a" and "O" of the seller's name. lastly, i've search this forum but there's no info on this type of fog lights or its harness setup.....thanks.
http://cgi.ebay.com/ebaymotors...wItem
[IMG][/IMG] http://i20.ebayimg.com/03/i/000/c1/fd/3be8_1.JPG
Old Nov 20, 2007 | 05:25 PM
JDM_SOHC's Avatar
Default Re: another fog light question (tuby)
isn't that the plug that goes to the OEM fog light switch??
Old Nov 20, 2007 | 05:28 PM
tuby's Avatar
Default Re: another fog light question (JDM_SOHC)
which switch is that...is it the one that goes into the signal/light control on top of the fat plug? the switch that came with the plug does not have room for the single brown plug, it only has room for the 4 wire plug
Old Nov 20, 2007 | 05:41 PM
Neebs's Avatar
See if this help. If not I will open my panels to check since I forgot where it plugs in.
http://handaaccessories.com/ci...s.pdf
Old Nov 20, 2007 | 05:53 PM
JDM_SOHC's Avatar
Default Re: (Neebs)
sent'm same link
Old Nov 20, 2007 | 06:12 PM
tuby's Avatar
Default Re: (JDM_SOHC)
i'm stuck on number 31...i can't find the plug behind the fuse box from the car harness. the switch harness has a brown female plug, i found a brown plug way back under the dash but it also is a female plug....any more advice?
jdoherty2
Lighting
Dec 26, 2013 01:10 PM
TeeHee
14
Dec 22, 2009 07:54 PM
tuby
Lighting
Nov 20, 2007 09:06 PM
AreJay126
Jun 16, 2006 01:13 PM
CHiNkStEr
May 17, 2005 02:36 PM
