Car won't Start
Old Nov 20, 2007 | 04:10 PM
Quad-Damage's Avatar
Default Car won't Start
Ok, Info, Car was starting before, didn't change anything.
Battery Volts Via Gauge 12.1 on start up, I have even tryed to start it with being jumped
Car is getting fuel 44 psi via fuel gauge and i can hear the pump walbro 255
Car is getting air, via boost gauge, and it almost starts
It cranks and sometimes shots exahust to not start
Replaced, NEW DIZZY and Ign
NEW MSD BLASTER 2 COIL
Did the spark plug trick, plugs have gas on them, getting fuel, took a plug out and put it on my block, getting alot of spark.
So i'm thinking starter, I try to bump start it / push start in 2nd, NOTHING
I went down my hill and back (great workout pushing your car uphill alone)
2 people push start still nothing. Tried like 10 times.
I have replaced the main relay as well, i tryed 4 different ones, the car cranks and turns over, just won't start.
Old Nov 20, 2007 | 04:23 PM
EASY101's Avatar
* B A N N E D *
I dont have a huge amount of experience with boosted cars but this doesnt sound like a starter problem. if you're getting fuel and spark have you checked your timing? I like your valve cover btw...
Old Nov 20, 2007 | 04:25 PM
Default Re: (EASY101)
The timing was marked with a marker when i changed the dizzy it was fine before, was not touched any different
that cover is for sale
Old Nov 20, 2007 | 04:48 PM
EASY101's Avatar
* B A N N E D *
I'm sure one of these gurus in here will be able to get you in the right direction.
Old Nov 20, 2007 | 04:51 PM
xenocron's Avatar
You need three things to start...
CONSTANT fuel, spark and compression...
1st, take some starting fluid (or carb clean) and spray it in the throttle body (open) for 2 seconds and try to start the car. If it starts for a second and dies...you have a fuel problem.
If it doesnt start at all...you most likely have a spark problem. If sometimes the car backfires, most likely you are out of time (or cam has jumped teeth).
Lastly, check that you have compression.
If the car cranks over...the starter is not your problem.
Old Nov 20, 2007 | 04:53 PM
kyden's Avatar
Default Re: Car won't Start (Quad-Damage)
is that a recent pic?
it sounds to me like you're not getting spark at the correct time.
Old Nov 20, 2007 | 05:43 PM
SPOON_BeIgHtEeNsEe's Avatar
check ur fuses...
Old Nov 20, 2007 | 06:15 PM
Tippyman's Avatar
Default Re: Car won't Start (SPOON_BeIgHtEeNsEe)
Check four things:
Spark, Fuel, Timing, and Compression.
If you have all four of those things, it should at least try to run.
Old Nov 20, 2007 | 06:46 PM
Default Re: (xenocron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xenocron &raquo;</TD></TR><TR><TD CLASS="quote">most likely you are out of time (or cam has jumped teeth).
Comp should be good, motor was just rebuild a week ago, ran strong a week ago
ITs just about to turn over, like 1 second before the car starts and it just stays like that
Old Nov 20, 2007 | 06:50 PM
Tippyman's Avatar
Default Re: (Quad-Damage)
It sounds like timing to me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damage &raquo;</TD></TR><TR><TD CLASS="quote">Comp should be good, motor was just rebuild a week ago, ran strong a week ago
That's a big SHOULD. You don't know what happened. Maybe something went wrong in that rebuild.
Old Nov 20, 2007 | 08:12 PM
skellator_thoj's Avatar
Default Re: (Tippyman)
yea, sounds like timing is off.
Old Nov 20, 2007 | 08:16 PM
Drew Peacock's Avatar
Default Re: (skellator_thoj)
valve stuck open? Do a compression test.
Old Nov 20, 2007 | 10:24 PM
FaceTuned's Avatar
this looks like the engine in that 4 door ek in the honda-tuning mag?
Old Nov 20, 2007 | 10:55 PM
DSRxSALSA's Avatar
Default Re: (FaceTuned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FaceTuned &raquo;</TD></TR><TR><TD CLASS="quote">this looks like the engine in that 4 door ek in the honda-tuning mag?</TD></TR></TABLE>
ding ding we got a winnerrr
Old Nov 21, 2007 | 01:47 AM
jdmsiR20's Avatar
Default Re: (DSRxSALSA)
you have a known good ecu? definitely worth a shot for you to test it out.
Old Nov 21, 2007 | 04:30 AM
GraphiteAccord's Avatar
Default Re: (jdmsiR20)
distributer is put on 180 degrees out. or the belt jumped a couple teeth.
Old Nov 21, 2007 | 08:38 AM
SOHC_MShue's Avatar
This sounds like an issue i had a few weeks ago. I was running a customer's car at the track for him and as soon as i shifted into 2nd the car just took a ****, lost all power, and barely made it to the end of the track before cutting off. We checked everything...fuel good, spark good, compression good, cam timing good, etc. Turned out to be the rotor button in the dizzy had cracked and shifted throwing spark timing way off. It was getting spark, but apparantely not at the right time.
Old Nov 21, 2007 | 08:45 AM
Default Re: Car won't Start (SOHC_MShue)
I just had my dizzy rebuilt by redzone and i saw him do it.
Old Nov 21, 2007 | 10:54 AM
dpetro1's Avatar
Default Re: (GraphiteAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GraphiteAccord &raquo;</TD></TR><TR><TD CLASS="quote">distributer is put on 180 degrees out. </TD></TR></TABLE>
not likely. they only go on one way. someone would have had to remove the teeth that go in the cam and flipped them.
OP, you should confirm all of the other things people have been talking about. compression, timing, etc.
Old Nov 21, 2007 | 01:43 PM
e she i's Avatar
Default Re: (dpetro1)
have you check all of your plug wires to see if they're in the right firing order?.
Old Nov 21, 2007 | 01:47 PM
Default Re: (e she i)
They are the same as my 1993 dx hatch
1,3,4,2 starting at the lower left of the distributor cap and rotating clockwise. the cylinders are numbered 4,3,2,1 left to right. right
i thought that was the case as well, but it's not
Old Nov 21, 2007 | 02:20 PM
93supercoupe's Avatar
it sounds ti me that u have ur plug wires mixed, although i dont know the timing order off the top of my head.
now that i think about it,
12
34
looking at it from the passenger side frender
one being the closest to the distro and 4 the furthest, and i know its labeled the other way around.
Old Nov 21, 2007 | 04:13 PM
Default Re: (93supercoupe)
plugs are in this order, my catch can is higher then it sits now btw
fucken autolight starter broke on me, haha ill take a pic with my cell, still wont start
Old Nov 21, 2007 | 04:25 PM
got compression? Simple test take 5mins.
Old Nov 21, 2007 | 04:37 PM
Default Re: (Drew Peacock)
car wont start
&lt;embed src="http://lads.myspace.com/videos/vplayer.swf" flashvars="m=22526188&v=2&type=video" type="application/x-shockwave-flash" width="430" height="346"&gt;&lt;/embed&gt;
Add to My Profile | More Videos
IT"S SO CLOSE TO STARTING
nice!
GOOD THING i had a spare y8 starter
I wish i could fix it without towing it to a shop, i need to buy a comp tester, I'm taking everyone ideas in as well
