crazy high idle after cleaning throttle body HELP
Old Nov 20, 2007 | 03:23 PM
jcfreibert's Avatar
Default crazy high idle after cleaning throttle body HELP
about a week ago i cleaned my throttle body and ever since then my idle is really high between 2-3k. ive been reading through all kinds of topics that ive searched on h-t and yesterday i cleaned th IACV and still i have this high idle. if im coming to a red light and take the car out of gear the rpms will stay @ 2-3k if i blip the gas pedal they will fall and idle just like normal....its almost like the butterfly is sticking just a hair ....any suggestions....can i put any lubrication where the butterfly closes @.....any suggestions would be appreciated
92 civic cx hatch
b16a
Old Nov 20, 2007 | 03:37 PM
Maxcapacity's Avatar
Default Re: crazy high idle after cleaning throttle body HELP (jcfreibert)
http://www.ef-honda.com/ben/Badidle.php
Helped me solve my problem, was bubbles in the coolant.
Old Nov 20, 2007 | 03:40 PM
Brick Top's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jcfreibert &raquo;</TD></TR><TR><TD CLASS="quote">
about a week ago i cleaned my throttle body and ever since then my idle is really high </TD></TR></TABLE>
you should look over what you took off.
Old Nov 20, 2007 | 04:29 PM
jcfreibert's Avatar
Default Re: crazy high idle after cleaning throttle body HELP (Brick Top)
i dint really take anything off...i sprayed the cleaner in the throttlebody... and scrubbed inside with an old toothbrush....and afer i cleaned the iacv i bled the coolant
Old Nov 20, 2007 | 04:42 PM
Brick Top's Avatar
then your plate could be sticking. lube her up haha
Old Nov 20, 2007 | 06:44 PM
jcfreibert's Avatar
what could i use that wouldnt be harmful to the motor?
Old Nov 21, 2007 | 09:21 AM
Brick Top's Avatar
wd40 shouldn't hurt. just don't spray a whole lot.
Old Nov 21, 2007 | 01:42 PM
King V's Avatar
Default Re: crazy high idle after cleaning throttle body HELP (T- rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T- rex &raquo;</TD></TR><TR><TD CLASS="quote">http://www.ef-honda.com/ben/Badidle.php
Helped me solve my problem, was bubbles in the coolant.</TD></TR></TABLE>
I'm with him . Even the techs I work with say make sure there are no air bubbles in the cooling system.
Old Nov 21, 2007 | 03:53 PM
jcfreibert's Avatar
Default Re: crazy high idle after cleaning throttle body HELP (King V)
bled the system right after i cleaned the iacv.....it seems like the throttle plate is catching inside the throttle body
Old Nov 23, 2007 | 09:39 AM
Brick Top's Avatar
so did ya spray it with anything yet?
Old Nov 23, 2007 | 10:51 AM
jcfreibert's Avatar
just throttlrbody cleaner.....but it is surging now up and down....and if i plug the hole that goes to the iacv it stops....bled the coolant again still doin it....is there any way to test the iacv to see if its any good?
sevenfc
Mar 27, 2009 05:58 PM
magicguy
Jan 30, 2009 02:00 PM
black bandit
Jan 14, 2008 04:26 AM
jcfreibert
Nov 26, 2007 02:23 PM
ATS*Mark
12
Dec 22, 2005 07:14 PM
