high idle after cleaning throttle body...HELP PLease
Old Nov 20, 2007 | 03:21 PM
jcfreibert's Avatar
Default high idle after cleaning throttle body...HELP PLease
about a week ago i cleaned my throttle body and ever since then my idle is really high between 2-3k. ive been reading through all kinds of topics that ive searched on h-t and yesterday i cleaned th IACV and still i have this high idle. if im coming to a red light and take the car out of gear the rpms will stay @ 2-3k if i blip the gas pedal they will fall and idle just like normal....its almost like the butterfly is sticking just a hair ....any suggestions....can i put any lubrication where the butterfly closes @.....any suggestions would be appreciated
92 civic cx
b16a
Old Nov 22, 2007 | 02:01 AM
johnshiro's Avatar
Default Re: high idle after cleaning throttle body...HELP PLease (jcfreibert)
Try adjusting or cleaning the idle screw valve.
Old Nov 22, 2007 | 09:31 AM
db1_jdm's Avatar
Default Re: high idle after cleaning throttle body...HELP PLease (johnshiro)
yeah also make sure ur throttle cable is not binding
Old Nov 22, 2007 | 06:22 PM
jcfreibert's Avatar
Default Re: high idle after cleaning throttle body...HELP PLease (db1_jdm)
it has some slack....i was messing with it a little today....and its been surging up and down....so i unplugged the iacv it idled great....so im thinking maybe to try and clean it again..? should i spray some kind of lubrication on the valve itself?(not in the screen)
Old Nov 23, 2007 | 01:51 AM
blk_eg4's Avatar
i have the same problem but it would only go up to 1.5k-2k rpm..is there a way to fix this??
Old Nov 23, 2007 | 08:07 AM
B16B_coupe's Avatar
HRD PKR
Default Re: high idle after cleaning throttle body...HELP PLease (blk_eg4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blk_eg4 &raquo;</TD></TR><TR><TD CLASS="quote">i have the same problem but it would only go up to 1.5k-2k rpm..is there a way to fix this??</TD></TR></TABLE>
fast idle valve... search it on here or google
possible vacum leak
Old Nov 23, 2007 | 08:16 AM
jcfreibert's Avatar
Default Re: high idle after cleaning throttle body...HELP PLease (B16B_coupe)
my throttlebody doesnt have one(fitv)
Old Nov 24, 2007 | 07:28 PM
97grnrs's Avatar
when u cleaned it did u take it off or leave it on car? if u took it off did u use new gasket?? did u unplug the Idle air control valve when u did this? what did u use to clean it and how? did u mix the tps and map sensor plugs up? any check engine codes?
Old Nov 24, 2007 | 08:01 PM
jcfreibert's Avatar
Default Re: high idle after cleaning throttle body...HELP PLease (97grnrs)
i took it off the car....reused old gasket....and i unplugged the iacv and reset the ecu after.....the throttle isnt sticking anymore but i have that annoying idle surge almost like a vaccuum leak...but i cant seem to find one.....can the iacv cause some sort of leak?
Old Nov 25, 2007 | 08:58 AM
97grnrs's Avatar
get a new gasket for the TB. if u took it off its prob not gonna seal again with the same one.. and check to make sure u didnt get the sensors soaked in de greaser or somethin. but its prob ur gasket leaking air causing a vac leak the iacv has a rubber o ring gasket.. check to see if its still there if u took it off.
Old Nov 25, 2007 | 10:32 AM
jcfreibert's Avatar
didnt take the tb off..... just iavc...it still has the gasket on it....
Old Nov 25, 2007 | 01:48 PM
97grnrs's Avatar
maybe its too dirty inside and stuck in one position? ive had to bypass the iacv b4 sometimes its easier than finding the real problem which alot of things could be causing the idle to fluctuate.. but finding the problem is the right way to go.
Old Nov 25, 2007 | 06:27 PM
jcfreibert's Avatar
i think its the iacv bc when i unplug it everything is normal.....so aggrivating
Old Nov 26, 2007 | 05:14 AM
B16B_coupe's Avatar
HRD PKR
what did you do with the iacv?
clean the iacv...
Old Nov 26, 2007 | 02:23 PM
jcfreibert's Avatar
i cleaned it twice...one with brake cleaner....and then again with intake cleaner......its surging like i have a vacuum leak or something
jcfreibert
Feb 24, 2008 09:32 PM
mad21kid
Feb 18, 2008 12:52 PM
ekb16
Apr 26, 2006 07:47 AM
stRodda
Jan 13, 2004 04:32 PM
MeanGreenEG9
Mar 6, 2003 09:19 PM
