what ECU to use to keep OBD 2
hmm
i guess i should give some details of what i want to install.
I may get a different head.. eithere a f22a or h22a for a DSM manifold
then run a DSM manifold and turbo, probably stock size, with 310cc injectors. However im not 100% if this is the way i want to go, but i can only put down about 200 whp due to the auto tranny limits.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sony224422 »</TD></TR><TR><TD CLASS="quote">I have to keep obd2 in CT for emissions, so i was just wondering if theres an ECU that i can use for this? my car is also an auto.</TD></TR></TABLE>
auto and OBD2...not a lot of options. Emanage maybe or AFC hack...or just rock an FMU and check valves
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkb18 »</TD></TR><TR><TD CLASS="quote">Most chips suck because there is no tuneability. I just bought a hondata s300 installed in a obd2 socketed ecu. </TD></TR></TABLE>
No you didnt...you bought an OBD1 ECU with OBD2 plugs on it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkb18 »</TD></TR><TR><TD CLASS="quote">Thats what I meant by "obd2 socketed". </TD></TR></TABLE>
It's misleading to folks who don't know any better.
well i wouldn't mind a base map tune, i just don't wanna explode lol. But yeah, in CT now if your car is obd2 and you go back to obd1 they will not let you register it.. so i was also thinking that since its every 2 years, i guess i could swap it out for the stock one but then wouldn't i run into emission problems not to mention the risk of blowing something up while its untuned and running wild.
I mean this is basically a for fun setup, i have the dsm manifold and turbo with a wastegate, intercooling and piping, bov, injectors so i guess i'd jsut need the downpipe and fuel managment.
We have the same thing in NC. I used to just swap out my chipped ECU for my stock ECU/injectors at inspection time. If I did another OBD2 car (which I probably won't), then I'd try an AEM FIC. It's a piggyback, but it looks pretty decent.
We have an FIC sitting in the showroom right now. Does look decent compared to the other **** out there I suppose. Haven't actually installed or used one yet but anything is better than an FMU I guess.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread/2126698</TD></TR></TABLE>
thanks!
i might look into that, i think i might have to use the stock EX ecu because im looking swap heads and would like a vtec head.
thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jay_Sensing »</TD></TR><TR><TD CLASS="quote">We have an FIC sitting in the showroom right now. Does look decent compared to the other **** out there I suppose. Haven't actually installed or used one yet but anything is better than an FMU I guess.</TD></TR></TABLE>
Well Emanage and Emanage Ultimate looked better than the other **** out there when it came out, and if you've ever dealt with one you know that they suck (compared to a re-mappable factory ECU or standalone). You can polish a piece of ****, chrome plate it, dip it in platinum, whatever. In the end, it's still a piece of **** piggyback. Keep in mind, I'm speaking in reference to using a piggyback to run a turbocharged engine on top of a factory NA ECU.
yeah i think i will have to use one of those.. which would be the better one to use.
i plan on doing a head swap.. either h22 or the accord ex head, and the ex ecu, and running a DSM turbo probably a 14b or sometihng..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_EM1 »</TD></TR><TR><TD CLASS="quote">2000 Si, OBD2b. It's a B16, but will be a Poorman's R on boost.</TD></TR></TABLE>
It should work fine for that, they just don't have a pre-fabbed wiring harness for it, so you'd have to wire it up using the ECU pinout guide from your Helms manual.
is it released yet?
and i guess i would have to make my own harness.. where would i be getting the connectors for it?
:edit: Yes its released.. and it does work with my car.. but is there a harness?
