Lighting HID/Xenon kits, Retrofits and Associated Topics
HELP! Electrical problem....running lights turn off whenever headlights turn on!?!
Old Nov 20, 2007 | 12:48 PM
esoterEK..'s Avatar
Default HELP! Electrical problem....running lights turn off whenever headlights turn on!?!
hljlkhj
Modified by esoterEK.. at 4:15 AM 3/4/2008
Old Nov 20, 2007 | 01:42 PM
slowSOHCvtec's Avatar
Default Re: HELP! Electrical problem....running lights turn off whenever headlights turn on!?! (esoterEK..)
sounds like a contact off the relay is stuck open. I recommend finding the relay and cleaning all the contacts..
Old Nov 20, 2007 | 03:59 PM
esoterEK..'s Avatar
Default Re: HELP! Electrical problem....running lights turn off whenever headlights turn on!?! (slowSOHCvtec
thanks for your input slowsohcvtec...
should the relay be under the dash fuse box or the under hood fuse box??
Old Nov 21, 2007 | 12:23 PM
MM&Y of car? A helms manual will give you the relay # you want to check. Usually the contacts which change state from that relay are located on the relay itself, but sometimes are located differently.
You need to find the wiring diagram of your car and trace it out. A relay for lights sounds like it may be bigger, check the relay names under your hood in the panel.
JTR
Jan 11, 2015 04:33 AM
tegdude227
Lighting
17
Jan 20, 2008 06:02 PM
slammin86
Oct 13, 2007 08:02 PM
92wraith
Oct 12, 2005 06:31 PM
el_Presidente
May 11, 2003 01:36 PM
