93 civic not turning over
Old Nov 20, 2007 | 11:50 AM
mikeweaver85's Avatar
Default 93 civic not turning over
I have a 93 Civic EX. The upper radiator hose burst from age on the highway the other day, and I had the car towed to my house. Today, I replaced the upper and lower radiator hoses, thermostat, and radiator cap; and then I did a flush and refill with 50/50. The car has battery power, spark and fuel, and a good starter; and it was running just fine only 48 hrs ago. Now - with all repairs completed - the engine does nothing when I turn the key in the ignition.
So far I have tried: the dome light test (dome light stays on), resetting the ECM, error code check (no codes), and jumping the car off, to no avail; the car stills does nothing, even though all lights and accessories do work.
I'm stumped, can anyone help?
Old Nov 20, 2007 | 11:54 AM
fmrprojects's Avatar
Default Re: 93 civic not turning over (mikeweaver85)
did you remember to put the ground back on? its on the thermostat housing
Old Nov 20, 2007 | 11:58 AM
Default Re: 93 civic not turning over (fmrprojects)
yes, and later I went back and took it off again and cleaned it and put it back on, just to make sure; still no luck.
Old Nov 20, 2007 | 01:27 PM
Anyone else have any ideas? This is my DD and I need to fix it quickly, but I got nothing, I'm baffled.
Old Nov 20, 2007 | 02:02 PM
zippo1130's Avatar
does it crank?
Old Nov 20, 2007 | 03:30 PM
Default Re: (zippo1130)
No, it does not crank over, I think I can hear the fuel pump cycling on and the starter solenoid clicking, but I've got zero crankshaft rotation. The other night, I turned the engine off as soon as I noticed it was overheating, and I pulled off the highway; then I noticed the burst hose and had it towed. I don't think it is likely for the motor to have suffered permanent damage, but tomorrow I'll have to see if the engine has seized. If not, then I have no idea why it will no longer turn over. Hopefully someone here has run into a similar problem and knows something else that I should double check.
Old Nov 20, 2007 | 03:42 PM
zippo1130's Avatar
maybe bad starter solenoid? try tapping it, with like a pipe and hammer, and see if it starts after that.
Old Nov 21, 2007 | 07:25 AM
Thank you zippo1130, I went back out to the car this morning and gave the starter and solenoid a few taps with a hammer and socket driver and the car started right up.
Nation Decay
Aug 23, 2018 10:17 AM
ej_type_R
Nov 5, 2007 05:03 AM
jared99
21
Apr 17, 2006 12:17 AM
Polish_dude
Dec 4, 2005 11:16 AM
moreno
Jan 26, 2005 12:08 AM
