Crank angle sensor location
You can't use a 92-95 sensor on a 96+ engine without changing the distributor and wiring it to work.
You can't use a 96+ sensor on a 92-95 engine without changing the oil pump to a 96+ one and wiring that to work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluedlude »</TD></TR><TR><TD CLASS="quote">like matt said, if you have a 92-95 the crank angle sensor will be in the distributor. if you have a 96-01 it will be on the oil pump housing.</TD></TR></TABLE>
Fixed
Fixed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 »</TD></TR><TR><TD CLASS="quote">
Fixed
Yeah, I have no idea where the oil pump is. A little help? Is it in the oil pan?
Fixed
</TD></TR></TABLE>Yeah, I have no idea where the oil pump is. A little help? Is it in the oil pan?
It is behind the crank pulley, behind the lower timing cover.
That front end "snout" of the crankshaft comes right through the oil pump. To get at those sensors you'll need to take the crank pulley and lower timing cover off.
