Help...How do you remove the shift linkage from a transmission?
Old Nov 20, 2007 | 08:12 AM
97SS's Avatar
Default Help...How do you remove the shift linkage from a transmission?
I have a spare 88 CRX HF transmission that I want to put in storage but I want to remove the shift linkage from it to make it easier to store (it won't fit with it on) but I don't know the best way to remove it.
I could hack saw the thing off but I'd rather do it the 'right way' if possible. Any help would be appreciated.
Thanks in advance...
Here's a pic of what I'm talking about...
Old Nov 20, 2007 | 08:19 AM
gursh d's Avatar
Default Re: Help...How do you remove the shift linkage from a transmission? (97SS)
Have you removed the spring pin? In order to remove the shift rod, you need to remove the spring pin, then it just comes right out. Get the right size punch, and just hammer it out...it will take a few good hits.
Or you can try Wes V's method: http://www.performanceforum.co....html
It gives alot of people trouble, but just search for 'bitch pin' and you'll find an different methods. I ended up buying a tool from matco specifically designed to remove spring pins.
edit: here's a thread I made a while back: https://honda-tech.com/zerothread?id=1993271
Old Nov 20, 2007 | 08:46 AM
97SS's Avatar
Default Re: Help...How do you remove the shift linkage from a transmission? (gursh d)
Cool...thanks for the links! I'll try the C clamp way first...then hammer that little biatch out if need be.
Old Nov 20, 2007 | 09:39 AM
HandleTech's Avatar
What I use is an A/C pump mounting bolt (the end looks sharpened)
If your not good at hand/eye coordination...
you might want to hold the bolt with some channel locks or vice grips.
Make sure youve got it aligned straight.
Youve got to hit it like its your little sister's BF....
DOnt be scared of it, its only a bitch pin.
GL man!
Old Nov 20, 2007 | 09:42 AM
alscrx's Avatar
Default Re: Help...How do you remove the shift linkage from a transmission? (HandleTech)
If you go to sears and get the correct punch that craftsman makes, it comes out with a tap!
Old Nov 20, 2007 | 03:09 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: Help...How do you remove the shift linkage from a transmission? (alscrx)
you need an 8mm punch, or any bolt that is 8mm in diameter to get that pin out.
Old Dec 10, 2007 | 09:37 AM
97SS's Avatar
Default Re: Help...How do you remove the shift linkage from a transmission? (sanimalp)
Thanks fellas for all your help.
I just wanted to say how I did it incase others were trying to figure it out too.
I went to OSH and did get a $12 8 inch C clamp and a correct sized 'punch' for ~$7-$8 but as a back up I got a pack of two 1.25" long 6mm screws for a whopping $0.59. The right size probably is 8mm but the threads on a 8mm screw would probably make the screw too thick to fit inside the bitch pin, at least that's what it looked like to me so I decided to go with the 6mm ones.
I decided to try the 'easy' methods first, so I tried the C clamp with a screw to 'push' through but that was a pain in the *** since the screw kept falling while trying to compress the C clamp. I think this might be best if you have 3 hands or a friend helping you out.
So on to cheap method second, the screws. Since these were 6mm screws they fit very gently into the bitch pin's recess and stay there with a little force to compress it in. Then with a relatively small hammer (since I don't own a large one) I gently tapped on the screw until it came out. After about 3 slight hits it popped out nice and intact.
It really came out easy without requiring hard hammering on it as I originally thought it would need. So I returned the unused/upopened punch and saved myself $8 and $12 for the C clamp so not bad for a $0.59 solution!
Thanks for everyone's input!
Modified by 97SS at 11:00 AM 12/10/2007
Old Dec 10, 2007 | 10:18 AM
kalm_traveler's Avatar
I've been using the chuck key for my drill... it's ends are beveled and seem to fit the bitch pin almost as good as the correct spring pin punch would.
b18c4door
26
Nov 23, 2007 04:47 AM
say_xiong
Sep 21, 2006 11:34 PM
Tealeg88
Nov 25, 2005 10:51 PM
migs
Sep 7, 2004 06:01 PM
ScootinIntegra
Apr 7, 2004 12:44 AM
