Is there a hub cap that fits 15" steelies? 96
Old Nov 20, 2007 | 05:35 AM
m735is's Avatar
Default Is there a hub cap that fits 15" steelies? 96
Not a wheel cover, just the center hub.
I don't care what car it comes from. I looked on the wheel tire forum and didn't find anything. Part numbers, make or model with year, if they exist. Thanks.
Old Nov 20, 2007 | 05:43 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Is there a hub cap that fits 15" steelies? 96 (m735is)
are you just looking for a cap to cover the axle nut?
Old Nov 20, 2007 | 08:25 AM
JimBlake's Avatar
The ones that I know about won't fit.
Mid-'80s Jetta had some small wheel covers, maybe 8" diameter. They used little clips but the wheels had to be drilled for them. Maybe you could drill?
My older BMW had center caps that snapped directly into the center hole, but your Accord wheels are hub-centric so that won't work.
Old Nov 21, 2007 | 03:59 AM
m735is's Avatar
Default Re: Is there a hub cap that fits 15" steelies? 96 (JimBlake)
Just the center cap to cover the axle nut. I've already tried my BMW ones, they don't fit (not even the TRX ones).
Old Nov 21, 2007 | 05:15 AM
GhostAccord's Avatar
Are you looking for a spindle & nut dust cover? If so they don't make them specifically for the 96 Accord. I found this online. I have no idea what the measurements are. you would have to call them and see what the OD is for the caps and find one that fits the ID of your hub.
http://www.partsamerica.com/Pr...=3134
Old Nov 21, 2007 | 10:57 AM
m735is's Avatar
Like these but for an accord.
http://cgi.ebay.com/ebaymotors...81860
Old Nov 21, 2007 | 11:29 AM
To find a set of those to fit 15's will be tough. Last time I saw a set of those was on an early 80's Civic with 13's.
Good luck with your hunt
Old Nov 23, 2007 | 02:08 PM
m735is's Avatar
The answer was sitting in my driveway. My wifes CRV has the steel 15" wheels and the center caps fit. I could have sworn I tried them before-love senility!
Now I just have to find some.
Old Nov 23, 2007 | 06:39 PM
That was easier than I thought it would be.
Here is a set for sale...$30 including shipping and they even state that they may fit on the Accord.
http://cgi.ebay.ca/4-HONDA-CR-...wItem
Old Nov 24, 2007 | 04:28 AM
m735is's Avatar
Default Re: Is there a hub cap that fits 15" steelies? 96 (GhostAccord)
Perfect, thanks!
Not sure why they didn't show up in yesterdays Ebay search, but I appreciate the link.
Old Nov 24, 2007 | 06:59 AM
Actually I think the ones in the link you posted should work as well. I just read there listing and it sounds like they will fit most Honda Steel rims from 84-00. The center hub dimensions for the steelies probably haven't changed. Not 100% though
Old Nov 24, 2007 | 10:49 AM
m735is's Avatar
I think those are the ones I tried a few months ago, from my Civic. They are too small as the Civic has 56.1 mm hub and the Accord has 64.1mm.
crxaddikt
May 4, 2014 02:50 AM
DarthTrader
Jan 12, 2011 09:13 PM
kaluwa3
Oct 13, 2007 06:47 PM
svselva
Sep 19, 2005 05:20 AM
manson
Apr 29, 2002 04:43 PM
