Been working on my MIG, Tell me what you think
I have really been working on my welding trying to get it down, is this kinda out it should look? I have not cleaned them up yet and I know they look a little dirty, I only wire wheeled them clean I did not use the Acetone. Just LMK what you guys think and if there is anything I should be doing?
You could see it coming through a little on the inside. I also checked for leaks using water and there was none.
It's kinda hard to spine the pipe when you are welding.
The top pic looks a little fatter because it is a small pipe going into a big pipe.
One thing I found ... lap joints are much easier than a true butt joint. One thing I have done to practice more (since I'm still learning as well) is to take a 12" section of pipe and cut it into 2" "rings". Then tack up all the rings and in 4 spots. Then doing one ring at a time, play around with wire speed, heat, head spead & head angle. I think my welder is decent, but could have better heat control.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91ed9 »</TD></TR><TR><TD CLASS="quote">your still using fluxed core?
(what type of gas are you using) [name]</TD></TR></TABLE>
You mean like Argon?
Not sure of the name, I get it at Tractor supply.
Should I turn the gas up? I think it is on like 20 If that means anything.
Assuming both pieces are fairly thin (14-18ga) Anywhere metal is blue it's a bit too hot. Try and set your machine to exactly what it recommends for that thickness, Argon/C02 mix is ideal for what you are welding and will allow better pentatration at lower amperage. What machine do you have? What wire diameter?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid2007 »</TD></TR><TR><TD CLASS="quote">How far away are you holding the torch from the pipe? That amount of spatter could be because you are too far away.</TD></TR></TABLE>
That could be, I am still learning and it's a bitch teaching your self with having no idea of welding, only what I have seen on here.
Looks like a good machine, my friend has the same one or close to it. Thing is Hobartgot bought out I do believe, so if anything breaks you may run into problems finding parts. What kinda patern are you using. When I butt weld exhaust pipe I first make sure their are barely any gaps in your work, and then put atleast four tacks all the way around, I personally use a straight pattern and a circle pattern on thin but welds like that, make sure you don't move too slow but at the same time not too fast. Arc Length should be around 1/4-1/2 inch. Also 20 cfm should be sufficient when welding mild steel. I usually keep mine on about 15cfm. When you run out of gas try a 75/25 mix of argon and co2. Also another thing I noticed about the hobart machine, They come from the factory wired up for fluxcore wire, so make sure you have the machine wired in DC+ all it required is opening the panel on the side of the machine and swapping the ground and pos wires. Their should be a diagram of how to wire it up on the inside of the panel if not look in your onwers manual. Good Luck!
---Ashby
Is your machine 110v or 220v?
---Ashby
I think it's 220V
I have the right wire in there. When I first started trying to weld I got a shity Flux welder.
So your saying when my gas runs out I should ask for a 75/25 mix?
The patern I am using is the )/)/)/)/)/)/)/)/)/)/)
That's the best I can do to show you lol
Should I just go in a line and not zig?
if thats you setup above you have blueshield which is 74% argon 24% and 2% co2. its good for welding mild steels. If your going to weld aluminum or stainless you want argon. straight argon comes in a brown bottle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBURKE »</TD></TR><TR><TD CLASS="quote">I think it's 220V
Should I just go in a line and not zig?</TD></TR></TABLE>
zig zag to spread heat... you dont need to clean it with acetone, just make sure the majority of the paint/dirt/rust etc is cleaned away, and wipe down any oil with a rag, ive never used acetone or wire wheeled before (atleast not before using a mig) i layed a bead with a mig, its just not vital if your using a good machine. My mig machine was well over 4k 2 years ago with just a few options and it burns damn good. Arc welding is the easiest, just tap and burn, burns right though everything haha!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p00n »</TD></TR><TR><TD CLASS="quote"> Also another thing I noticed about the hobart machine, They come from the factory wired up for fluxcore wire, so make sure you have the machine wired in DC+ all it required is opening the panel on the side of the machine and swapping the ground and pos wires. Their should be a diagram of how to wire it up on the inside of the panel if not look in your onwers manual. Good Luck!
---Ashby
Is your machine 110v or 220v?</TD></TR></TABLE>
Thank you so much for this!!!
I looked at it last night and it was wired up for flux. Would this mess up my welding at all?
---Ashby
yeah wiring it correctly should make a gigantic difference. There should be some settings on the inside of your welders case. They are usually pretty decent.
report back with pics yo.
