Exhaust manafold cherry RED
Can anyone tell me why some times my stock manifold is turning bright red after driving at normal conditions, I have just installed a 8lb flywheel and a stage 2 clutch, and a high flow cat. since this install I have noticed this prob. Please give me some help here.
Different things can cause high exhaust temps...not enough fuel, bad timing, clogged EGR, etc. What kind of 'high flow cat' are you using?
like im sayin I have no idea? the exhaust sounds the same and seems to be dumpin the same out the rear but the manifold is gettin red at diffrent times not all the time. some times when im just crusin and then sometimes not? Its nuts. Im wonderin if its hurting anything. the O2 sensors are not working sence I put it on so could that have an affect?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tacticalcustoms »</TD></TR><TR><TD CLASS="quote">isn't hot exhaust temps caused by the car running too lean or the timing is off right?</TD></TR></TABLE>
x2.
ssomething might be clogged maybe in the "spoon" cat? ebay sometimes does that to you.
x2.
Yes but the difference isn't this huge, I really think he has an exhaust "clog" he doesn't know about.
hmm..never seen the stock header without the heatshield on. Maybe they all turn red lol
Mine almost looked red all the time though anyway. Maybe theres an obstruction in the flex pipe in the 2-1 piece too. But I'm agreeing its an obstruction somewhere in the exhaust system.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M2B4 »</TD></TR><TR><TD CLASS="quote">I was browsing the spoon catalog didn't see any high flow cats for our cars. hope u didn't pay 2 much</TD></TR></TABLE>
ebay
ebay
If he had such a blockage that the headers was heating up he would more than likely loose tons of power aswell. I experienced this with my h23. Felt like someone was pushing me rather that actually having a motor. Does it lag any?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BB6rude »</TD></TR><TR><TD CLASS="quote">theres no lag its haulin ***!!! and YES!!!!! It came off EBAY but thats not the debate. I realize that its a cheap cat!!!!!! </TD></TR></TABLE>
It's probably a hollow pipe, not a cat.
