LS Econo Billet Rods with P30 Pistons???
Old Nov 19, 2007 | 08:08 PM
kdawgy2k1's Avatar
Default LS Econo Billet Rods with P30 Pistons???
I had a question about a set-up here and i was wondering will LS econo Billet rods fit OEM Honda CTR Pistons... I heard with OEM LS rods the upper wrist pin section has to be thinned down a bit because of the thickness of the rod... i was wondering if this applies to the Econo Billets as well or is there a particular rod for this set up that will all work together without the machining or thinning...
Also does anyone know about how much to take off with stock or aftermarket rods or is it a try and see if it fits now kinds thing??? LOL
Thanks
Old Nov 23, 2007 | 06:56 AM
kdawgy2k1's Avatar
Default Re: LS Econo Billet Rods with P30 Pistons??? (kdawgy2k1)
Bump:
Old Nov 23, 2007 | 01:18 PM
NJIN BUILDR's Avatar
You will also have to deal with the fact that the rod are most likely floating pin and the piston requires a press fit rods.Does the piton have grooves for wrist pin clips?Will the pin slip into the rod by hand?You ask about CTR and P30 as if they are the same piston.They are not.
Old Dec 9, 2007 | 06:09 PM
lambertincorp's Avatar
Default Re: LS Econo Billet Rods with P30 Pistons??? (NJIN BUILDR)
stop right while boost is still an option i know you will do the right thing...see ya later hope u got a fat taco ready
almostjdmeg
16
Aug 20, 2015 11:10 AM
EgK2o09
Feb 1, 2010 06:29 PM
k24a4kid
Oct 9, 2005 02:55 PM
fox297
Aug 4, 2003 12:39 PM
