wires for sony cd player to honda radio harnes
hi im putting a sony cd player in to my civic and i wanted to know which wires match up from the sony harnes to the honda harnes i cut the honda harnes clip so i have to wire it up any body know the sony to honda wires???
yeah..buy an adaptor harness. if you ever wanna take out that radio you'll be all botched up. at least with a harness you can go back to stock if you ever want to. plus it makes for a cleaner install.
I KNOW THIS i fucked up and i need t know the sony to honda wire code any one know i cant buy a harness now
Buy a harness and use that to figure out what wires go where, then return it.
luckily i work in a stereo shop so here you go
front left speaker-blue/green&gray/black go to white&white/black
front right speaker-red/green&brown/black go to gray&gray/black
rear left speaker-blue/yellow&gray/white go to green&green/black
rear rightspeaker-red/yellow&brown/white go to purple&purple/black
12 volts-white with colored stripe(usually yellow or blue stripe) goes to yellow
ground- black goes to black
switched- yellow/red goes to red(test this wire with a volt meter i can't remember but i'm pretty sure this is it though)
hope this will help
hope this will help
what about the white from the sony harness and the illumination for the face to light up isnt that red wit black stripe on honda harness??
white is the front left speaker and the red/black striped wire in your honda is the illumination wire goes to the orange/white striped wire on the sony harness
hey man here is the wire diagram off our computer at work:
12 volts-white/blue
accessory-white/green or yellow/red
ground-black
power antenna-yellow/white
illumination-red/black or blue/white
front left speaker positive-blue/green
front left speaker negative-gray/black
front right speaker positive-red/green
front right speaker negative-brown/black
rear left speaker positive-blue/yellow
rear left speaker negative-gray/white
rear right speaker positive-red/yellow
rear right speaker negative-brown/white
hopefully this will help.
12 volts-white/blue
ground-black
EFing8
Audio / Security / Video
Nov 13, 2002 08:08 PM
