gsr crank/rods w/ b16 pistons in ls block
im getting ready to throw a block together with some parts i have lying around since i donthave the money to spend on piston/rod setup right now.
i have a gsr block that cyl walls are screwed..
however rods/crank are still good....
so what i was going to do is remove the pistons from that setup and get a set of b16 pistons pressed on that i have lying around...
i also have a bare ls block that im going to install it all in, but before i get to crazy i just wanted to ask for a few opinions and pros/cons to the setup..
any help will be appreciated..
thanks
thanks
ur decreasing the stroke and raising the compression. sounds fine to me.
i would also use the gsr girdle and get some arp rod bolts.
mymeatb18"
Jun 26, 2006 03:16 PM
Irishweird00
11
Jun 5, 2003 06:51 PM
