lower timing belt cover reinstallation help
Old Nov 19, 2007 | 06:04 PM
BB6racer's Avatar
Default lower timing belt cover reinstallation help
i've been wrestling with my car for the last hour just trying to get the lower timing belt cover back on. is there a trick to doing this? like taking off the engine mount, suspension components, rotating the cover a certain way, etc... it came off pretty easy, but i cannot get it back up there for the life of me. the radius rod and axle are blocking it from the bottom, and the engine mount and pulleys block it from being lowered in. i'm about to shoot my car!
Old Nov 19, 2007 | 06:09 PM
Acidcrakker's Avatar
Default Re: lower timing belt cover reinstallation help (BB6racer)
I took off the Altenator and AC, that helped.
Old Nov 19, 2007 | 06:24 PM
Sampsonite987's Avatar
Default Re: lower timing belt cover reinstallation help (Acidcrakker)
I hear you man, I went through the same damn thing a couple weeks ago. Sucks doesn't it. I didn't remove anything, although it may have made it easier. I just messed with it trying different ways. Removing the radius rod will probably make it easier, that is what was jamming me up.
Old Nov 19, 2007 | 07:05 PM
vinuneuro's Avatar
Default Re: lower timing belt cover reinstallation help (Sampsonite987)
Put it in through the bottom for sure. In my 5g I snuck it in past the radius rod, and upwards. Once it's in far enough along, pull it into place from the top.
michaellong
Aug 20, 2018 04:05 PM
mem94043
May 16, 2011 12:28 PM
fiebru1119
Dec 11, 2010 07:30 PM
my00SI
May 18, 2009 11:54 AM
twistedbydezign
Sep 20, 2005 11:05 AM
