Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
CR-V Brakes _ Mechanic want to clean and service is it necessary.
Old Nov 19, 2007 | 04:44 PM
caliskier's Avatar
Default CR-V Brakes _ Mechanic want to clean and service is it necessary.
My sister drives a 1999 CR-V/ Periodically the brakes squeek and the breaklight comes on sometimes in the morning. She went to have the tires replaced and she asked the mechanic to check the brakes. They said the pads and roters were fine but that she might want to get the rear breaks cleaned and adjusted. Is this necessary?
Old Nov 19, 2007 | 05:39 PM
IMALLSLO's Avatar
Default Re: CR-V Brakes _ Mechanic want to clean and service is it necessary. (caliskier)
Yes its needed. Out of adjusted rear shoes will cause a squeak or groan when braking. As for the brake light,id recommend replacing the brake fluid sensor on the brake master. It gives false readings that the fluid is low thus illuminating the light. The part will run around $35-40 with the filter.
Old Nov 19, 2007 | 08:06 PM
caliskier's Avatar
Default Re: CR-V Brakes _ Mechanic want to clean and service is it necessary. (IMALLSLO)
Thanks very very much!!
Old Nov 20, 2007 | 10:47 PM
bittles110's Avatar
I see a "clean and adjust" as a way for shops to make money. Yes, improperly shoes can lead to problems, but most noticeably the parking brake not holding the vehicle very well. If it needs it, do it.
As for the brake fluid light, IIRC there is a TSB on a new and improved brake fluid reservoir that properly vents pressure in varying temperatures. The sensor does not need to be replaced.
Novacoma
Honda CR-V & Element
Jun 28, 2017 01:35 PM
adamcm16
Apr 10, 2014 05:07 PM
Jaydeep
Jun 25, 2012 09:25 PM
ElCivic89
Mar 16, 2012 01:54 PM
Nessal
Sep 3, 2005 06:24 PM
