CAR WONT START
Old Nov 19, 2007 | 03:44 PM
rockenuptown's Avatar
Default CAR WONT START
my car wont start its an 1988 honda civic lx and i cant start it when i start it it cranks slow and all lights go real dim like low power i try to hook it up to jump start it but when i do that it turns faster but it starts for a sec but wont go above 500 rpms and its real slow like omg slow sort of lack of power i checked all grounds i think and all realys are fine whats does anyone else have this problem
Old Nov 19, 2007 | 04:31 PM
JDMatt3's Avatar
Default Re: CAR WONT START (rockenuptown)
try taking off your distributer cap and tightening up the rotor...might work...idk
Old Nov 19, 2007 | 04:34 PM
JimmyM86's Avatar
check all the basics:
spark plugs
condition of wires
condition of dist. cap
condition of rotor
condition of gas
condition of battery
condition of alt
condition of your search button (your fluid may be low)
Old Nov 19, 2007 | 04:43 PM
Default Re: CAR WONT START (JimmyM86)
i check the dis. cap before and the rotor screw was off i put it back on it ran good then i went like 2 mins. up the road it cut off i thought it could of came loose again i checked it i was still tight and wouldnt start since then i got new spark wires and dis.cap and new spark plugs but nothing i tried to jump it and it cut on for about a minute then cut off it made a sound like a weak power to it like a thump sound like it was struggleing to stay alive
Old Nov 19, 2007 | 06:29 PM
1 Fly SI's Avatar
Is your battery light on?
Old Nov 19, 2007 | 06:52 PM
alscrx's Avatar
Default Re: CAR WONT START (1 Fly SI)
Whats the battery voltage??
Dim lights sounds like a voltage problem to me.
Check all your fuses, inside and underhood box.
Let me know the results
Old Nov 19, 2007 | 08:47 PM
mechmunkee3's Avatar
try taking out your ciggarette lighter. my car will shut off if the lighter is pressed in... just a thought
Old Nov 19, 2007 | 09:00 PM
Default Re: (www.FEOA.net)
cig. lighter is out always has been and the battery light is always on like its supposed to be unless its started
Old Nov 20, 2007 | 10:50 AM
Default Re: (rockenuptown)
i think the batterys gone theres no jumping it now
Old Nov 20, 2007 | 10:54 AM
wiZCo's Avatar
Stouts 'n' Scotch
Take it to Autozone and have them test your alternator and battery. That's if you can get it started again. Also, make sure all your battery grounds are tight and not corroded.
Old Nov 20, 2007 | 10:57 AM
Default Re: (wiZCo)
i think its the alternator cause the batterys only 3 weeks old
Old Nov 20, 2007 | 11:10 AM
SIred91's Avatar
Rainman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rockenuptown &raquo;</TD></TR><TR><TD CLASS="quote">i think its the alternator cause the batterys only 3 weeks old</TD></TR></TABLE>
Ba dum Cha!
Old Nov 20, 2007 | 11:15 AM
Default Re: (SIred91)
what lol
Old Nov 20, 2007 | 11:21 AM
JustAnotherRex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rockenuptown &raquo;</TD></TR><TR><TD CLASS="quote">what lol</TD></TR></TABLE>
He's saying that's more than likely your problem. If the battery was replaced 3 weeks ago, that narrows down the list of things to check.
Old Nov 20, 2007 | 12:11 PM
Default Re: (JustAnotherRex)
yea
Old Nov 24, 2007 | 05:14 PM
so did you get that all sorted out? what ended up being ur problem?
Old Nov 24, 2007 | 05:16 PM
greenEFSI's Avatar
check the 10mm ground on ur alternator! same **** happened to me
egbarteezy
Apr 5, 2011 05:01 PM
tuquikgsr
Nov 10, 2008 01:45 PM
CWITR
May 3, 2005 04:38 PM
