OBD1 D15B
Old Nov 19, 2007 | 03:10 PM
LIMITLESS22's Avatar
Default OBD1 D15B
Question..
Is the 92-95 D15B, 130hp version the only one with the black valve cover?
I've go one, not sure what its from but it has the black valve cover, single vtec
solenoid and there is a stamp p08 on the ex. side of the head.
Old Nov 19, 2007 | 03:21 PM
Bejita's Avatar
Yes...Thats an OBD1 Motor. It requires a P08 ECU to run properly.
Old Nov 19, 2007 | 03:23 PM
Default Re: (Bejita)
Thanks.
P08=JDM only?
Old Nov 19, 2007 | 03:54 PM
Bejita's Avatar
Yep.....You can buy one by calling the guys at http://www.hmotorsonline.com
Old Nov 19, 2007 | 04:05 PM
ejoner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bejita &raquo;</TD></TR><TR><TD CLASS="quote">Yes...Thats an OBD1 Motor. It requires a P08 ECU to run properly.</TD></TR></TABLE> Dude please stop giving people bs responses. Just because the motor has a black valve cover doesn't mean anything, and yes po8=obd1 you can run it on usdm p28 ecu. Running a jdm p08 ecu will make the car never pass smog, your going to have to run a single wire o2 and evap purge solenoid isn't going to exist in the jdm ecu. Run a p28 ecu and if you want to make everything perfect chip your p28 to p08 maps.
Old Sep 16, 2008 | 10:45 AM
LimitlessR's Avatar
Default Re: (ejoner)
bleedblue94
Mar 10, 2008 10:46 PM
b00sted4dr
Feb 7, 2008 09:17 AM
1sikhatch
13
Sep 29, 2007 06:01 PM
drvfast
Apr 4, 2004 09:18 PM
