CRX Camber help
hey all just slammed my rex and i needed to know what is the best front camber kit was. Skunk2 doesnt make one for the CRX specifically but i was wondering if any of the integra camber kits would fit the front.
is this car for handling or looks. if it is for handling you want the camber just get an alignment to fix your toe. you won't notice too much tire wear anyway if you just fix your toe. camber does not cause tire wear as much as you think. its toe. imho camber kit waste of money
Well i didn't slam my car i only lowered it 1.25" from tokico. I bought the crx camber kit with adjustable ball joints. Took it for an alignment and guy didn't need to adjust them. it was overkill on my part. He does adjust your tie rods though!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammin86 »</TD></TR><TR><TD CLASS="quote">
Yes get a camber kit and use washers on the back. </TD></TR></TABLE>
i'm dropped 2.25 in the front and 2.0 in the rear no camber kits. my camber in the front is -2.5 deg and in the rear it is -2.0. toe is 0 there is no noticeable uneven wear i have 12k miles on my tires. telling you watse of money the camber kits. you didn't answer my question tho is this for show or handling?
Modified by SFlCrx at 12:23 PM 11/21/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SFlCrx »</TD></TR><TR><TD CLASS="quote">
i'm dropped 2.25 in the front and 2.0 in the rear no camber kits. my camber in the front is -2.5 deg and in the rear it is -2.0. toe is 0 there is no noticeable uneven wear i have 12 miles on my tires. telling you watse of money the camber kits. you didn't answer my question tho is this for show or handling? </TD></TR></TABLE>
Exactly. Toe is going to kill your tires not the camber. I run almost 3deg up front and no uneven wear. I even have a camber kit in the rear to GAIN MORE camber as lowering it did not create enough for how I like my car setup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LumpyCRX »</TD></TR><TR><TD CLASS="quote">So the general consensus is front camber kits are not needed just an alignment?</TD></TR></TABLE>
ppl who understand how tires wear will agree.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LumpyCRX »</TD></TR><TR><TD CLASS="quote">Then why is everyone bent on telling me to get camber kits or else i cant fix my tire wear?</TD></TR></TABLE>
because they believe the lies.
you must get an alignment everytime you change ride heights. plain and simple. THATS the rule that everyone should be told. not simply "get a camber kit".
if you are drag racing, then you would want to even your camber as much as possible for straight line grip. but for handling, keep the negative camber for grip.
you do the alignment (fix toe, adjust tie rods) to save your tires.
