Oil Cooler
Old Jun 24, 2002 | 06:29 PM
TurBoXBirD16's Avatar
Default Oil Cooler
What's the main purpose of oil cooler??
if you want to cool down your engine, u would need a radiator, that's why we need an radiator, right?
then does an oil cooler cool down the engine also??
i am confused abit, please help
Old Jun 24, 2002 | 06:39 PM
YeuEmMaiMai's Avatar
Default Re: Oil Cooler (xbird)
an oil cooler keeps the temp of the engine oil lower therefore making it last longer before it breaks down due to thermal stress. It is usefull if you are a racer or like to get on it a lot. Lower oil temp helps engine run cooler as well.
For your everyday street use casual driver there really is no need for one and when you add one, it is just another place for something to leak out of...
Old Jun 24, 2002 | 07:05 PM
Default Re: Oil Cooler (YeuEmMaiMai)
how much usually does a oil cooler cost??
the cheapest one??
also, after the oil cooler is installed, does that always have to move the oil filter to another spot from the stock spot??
Old Jun 25, 2002 | 12:27 AM
travis's Avatar
Depends on the size and the quality. Expect to pay between $100-200 for most Honda sized coolers
the cheapest one??
Once you realize that your entire supply of oil will be sent through this system, you'll rethink the idea of saving money and buying the cheapest. A failure hear is not good.
Nope. You can use a sandwich adapter plate.
Don't forget, with an oil cooler, you need a block adapter and remote filter mount (or just a sandwich plate), oil lines, hose fittings, the cooler itself, and install hardware. Depending on your setup, the hose and fittings may cost more than any other individual part. It's not uncommon for a complete system to exceed $3-500.
You might find a kit that's priced at $100 for everything, but would you trust your motor to it?
Old Jun 25, 2002 | 12:45 AM
kinesistech's Avatar
Some cars must have oil coolers. Porsches were aircooled until 1999. But all of there engine used at least 10 quarts of oil and they all have oil coolers. They provide 20-30% of engine cooling in those cars.
Old Jun 25, 2002 | 06:46 AM
Crazydave's Avatar
Default Re: Oil Cooler (kinesistech)
Type-R comes with an oil cooler
Old Jun 25, 2002 | 06:57 AM
Default Re: Oil Cooler (ITR#231)
is B&M a good one?
how big the oil cooler is enough??
[Modified by xbird, 3:58 PM 6/25/2002]
Old Jun 25, 2002 | 07:06 AM
brcivic411's Avatar
i have the B&M unit. it's definitely not Greddy but it gets the job done. the B&M does come with a filter relocator but the nice thing about greddy is that the sandwich adapter has a thermal switch
Old Jun 25, 2002 | 07:13 AM
StyleTEG's Avatar
Default Re: Oil Cooler (brcivic411)
Yup, they hold tons of oil. More than 10 quarts in many cases. I changed the oil in a 95 911 recently and it had 11 quarts that dropped!
Old Jun 25, 2002 | 08:58 AM
Steve91's Avatar
B&M cooler are okay. You would be much better off with a quality unit like Setrab, Earls, or Fluidyne. I believe the Greddy is made by Earls. THe Greddy sandwich is a nice piece too.
Check this place out for a good selection http://www.bakerprecision.com/
Old Jun 25, 2002 | 09:17 AM
vtec2.0's Avatar
Default Re: Oil Cooler (Steve91)
check the hybrid board http://www.hybridgarage.com. AT did like an $80 oil cooler with all the same parts that the more exp coolers have. ss lines are ss lines. good fittings earls or aeroquip fittings are prolly better than the fittings on most kits. the core is the only thing in question and as long as it isn't leaking, they are all the same...imo
ryan
Old Jul 8, 2002 | 07:24 PM
N24RE's Avatar
Default Re: Oil Cooler (vtec2.0)
Check out my install in the R....it should help you understand what is going on...and how to do one...the link is in my sig
Ciao'
Old Jul 8, 2002 | 09:42 PM
Tweakmeister's Avatar
Default Re: Oil Cooler (N24RE)
don't forget Jackson Racing !!
kit looks pretty good too
Old Jul 9, 2002 | 09:45 AM
would a cooler which made to be a Transmissino cooler work as a oil cooler??
should be the same, right?
pityocamptes
May 26, 2015 03:45 PM
99lsvtecauto
Nov 28, 2003 09:37 AM
SoulSurfer
Nov 8, 2002 06:22 AM
94DelSolVTEC
Feb 1, 2002 06:31 PM
itr501
Oct 23, 2001 02:41 PM
