EK Rear upper control arms
I looked up on part number and the 96-00 civic's rear upper control arms, aka camber arm, and noticed that the arms have left and right side denoted.
I took out mine and looked at one of the arm, and the arm's one side is curved in where the other side of arm is curved out.
I was wondering if it is okay to put left UCA on the right and vice versa.
Just want to know if there is a reason behind having left and right side distinguished. LCAs are the same, but why not UCAs?
i had the same though just for ***** and giggles when i put on my camber kit, i really cant remember what my though process was, but my end result was "i better put these on right" so i suggest you do the same.
hmm the reason i am asking this question is because my passenger's side UCA was damaged and bought a used from from a junk yard. So basically i am running on two driver's side UCAs right now. I assumed the part is the same for left and right since LCA have no left/right specified.
They have different angles? what do you mean?? because the driver's side UCA fit without a problem on passenger's side. I can see the UCAs are mounted in an angle and I am thinking that may be the reason behind having left/right UCAs.
Thanks guys for your help!
swizz977
10
May 18, 2012 05:27 AM
Magick211
Feb 15, 2011 12:36 PM
Trey
Nov 12, 2001 12:50 PM
