swaybar bracket
i have a 95eg6 and i want to put my ls swaybar on but i dont know what is the size of bolt to use to hold the bracket to the subframe! its not a 12 or a 13mm neither a 14mm. there is the predrilled holes but do i have to tap the holes? help me on this.
their is no nut on the other side of the subframe on your car. you will have to buy nuts and put up in there to run the bolts into. when i did mine i taped them to paint mixing sticks to hold them until i could start the bolts.
